Large Bucket Container.
   / Large Bucket Container. #1
stray
Platinum Member
east TN
Power-trac 422 2003 model and 428 January 2015 model
Has anyone made a large container bucket or bought one for a PT 425/422? I am talking about one that would hold about 50 cubit feet of material. I am thinking about building one and would like to see or hear some ideas. Maybe one that you could make from an old oil tank or the like. Thanks Guys.
   / Large Bucket Container. #2
What would you be using it for? This amount of material would throw the center of gravity way forward. With the 10 cu bucket filled with normal load of dirt you have to be very careful to not tip forward. Compost would be perfect for larger bucket container.
PJ
   / Large Bucket Container. #3
If I were going to build one for compost, I might consider something that would attach to the pallet forks. Kind of like a large box with small sides on it to keep the compost from spilling out. The compost is much lighter than dirt and you could afford to carry more, 50 cu? Not sure about that though...
   / Large Bucket Container. #4
<font color="red"> 50 cubit feet of material </font>
If some's good, more's better. A 2 yard bucket, however, on a 425 may be a skosh on the high side, even for mulch.
But be sure to post pictures. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Large Bucket Container. #5
Is this what you are talking about.
   / Large Bucket Container. #6
That is a fiberglass laundry hamper.
“(What would you be using it for?)”
For raking grass into it off of the ground like when I dump the yard sweeper.
For placing pond moss into it (if the bucket is placed on the ground it would be much easer to collect the moss even if you need to fork it into it. It would also be much easer to dump the bucket than to get the moss out of a trailer.
For hauling fire wood (I believe the PT would handle at least 3 times as much wood as the 10 cu bucket would maybe more.
“(Is this what you are talking about.)?”
Something that would attach to the pallet fork would be ok but I do need it to meet the ground much like the bucket lip does.
(“If some's good, more's better.”) I agree that for things like dirt rock and other heavy material 54 cu would be a way too much. I will most likely end up making a 30 to 40 cu bucket and I will be careful not to over load it. As many of you all have said if the back end of the pt comes up you might be load heavy.
   / Large Bucket Container. #8
That is really cool - PERFECT
PJ
   / Large Bucket Container. #9
You may want to use expanded steel for bottom and sides to save weight. Most stuff like leaves and grass clippings won't fall through it and it weighs considerably less than sheet steel.
However, I'd still be concerned with front tipping. I don't know the math, but there is some formula that can figure out how far out you go = less weight it will lift.
OK, geniuses... I'm not too proud that I didn't take to math very well, so edumcate me on the math formula, please.
Here's what I want to know...
If the PT will lift 800 pounds at the quick attach plate
and
the front tires are the pivot point
and
we assume that the quick attach plate is 2 feet from the center line of the front tire...
How much weight will it lift 2 feet from the quick attach plate?
How much weight will it lift 4 feet from the quick attach plate?
How much weight will it lift 6 feet from the quick attach plate?
   / Large Bucket Container. #10
24"x 800Lb=19200, 19200 divided by 48"=400lb, 19200 divided by 60"=320lb, 19200 divided by 72"=267Lb. Of course you would need to add more of a stability factor the farther you go out.
   / Large Bucket Container. #11
I built one out of 1/2" plywood (box with open top and front) that I use to carry bales of hay with the forks. It is 4' x4' x 5'6"high . Holds 8 bales (400#) no PT pucker.
   / Large Bucket Container. #12
</font><font color="blue" class="small">(
and
and
How much weight will it lift 6 feet from the quick attach plate? )</font>
Simple lever physics. If at 2' from the wheels you lift 800# then if you move outward another 2' (twice as far) you can only lift 400#. At 6' out it would be 300#, and at 8' you would be down to 200#.
My best guess...
OnTheWeb
   / Large Bucket Container. #13
Sorry forgot to mention those would be the weights based on the arm length from the front wheel pivot, the 48" would then be 24" ahead of the attachment plate etc.
   / Large Bucket Container. #14
Thanks, folks! I should have studied harder. At least I know where to go to look up the information. /forums/images/graemlins/wink.gif
   / Large Bucket Container. #15
Hey MR....it doesn't matter what you know, so long as you know where to go to find out what you want to know !! /forums/images/graemlins/smile.gif
   / Large Bucket Container. #16
I used to open the dictionary, now I log on to TBN! /forums/images/graemlins/tongue.gif
   / Large Bucket Container. #17
When I lived in Houghton & Hancock (upper MI) we would get over 200" of snow a year and all the FEL's there had these huge snow buckets on them, then they would change back to something smaller for dirt in the summer. Maybe someone makes a snow bucket that you could make fit?
Here are a few links to snow buckets
Swepster/FFC snow bucket
Rockland snow bucket
Skid steer snow bucket
Tim
   / Large Bucket Container. #18
So, anybody have any idea how much .63 yard bucket full of wet snow would weigh? /forums/images/graemlins/confused.gif
   / Large Bucket Container. #19
Thanks for the links Tim. I was thinking about needing a snow bucket just yesterday, now I don't have to search hard.
Thanks Tim. Those may be a little large or expensive but that is what I have in mind. I'll let you all know what I finely come up with.
New Holland T2420 (A53317)
New Holland T2420...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
