Rake Landscape rake size help
/ Landscape rake size help #1
Bob_S
Central Ma
JD 4310 hydro, 4wd
I wish to purchase a rake and need some help. I have a 5 foot wide tractor (4310) and I not sure if I should go with a 5 or 6(+) foot rake. I dont mind the extra job time the 5 foot rake would cause. The only reason I am considering a 5 is so I can do tigher arears, paths, etc. Is a 5 foot rake just to small for a 5 foot wide tractor? Thanks! /forums/images/graemlins/smirk.gif
/ Landscape rake size help #2
Bob,
I believe you will want one that is wider than your tires. Otherwise you will leave marks from your tires. Check the width of your back tires, I would add a good 6" for each side and that is the one I would go with. Your tractor will handle the 6' easily
Just my 2 cents for whatever they are worth.
murph
/ Landscape rake size help #3
6' allows you to cover your tire tracks while it is angled, which apparently is a common practice. Same with back blades, which are often angled.
Mark
/ Landscape rake size help #4
<font color="blue">I have a 5 foot wide tractor (4310) and I not sure if I should go with a 5 or 6(+) foot rake... </font>
Hi Bob,
I'd get a 7' or a minimum of 6' for your tractor... (you're only talking maybe ~~$20-30 per foot difference) In many cases, you'll have the rake at an angle to disperse the debris off the end... so in this case it will have to be "longer" than the "width' of the tractor to make up the angle loss...
I used a 7' rake on my little 22 1/2 PTO hp Satoh and it works the nuts... so your 4310 will certainly not have any difficulty...
A 5' is just way too small and for a only few dollars more I believe you'd be much happier with "longer"... /forums/images/graemlins/smile.gif
/ Landscape rake size help #5
I have a 6 foot rake for my 4310. I'm glad I didn't go with a five foot. The 6' is perfect for my use. Covers the tracks, ability to angle and still gets into tight places when I need to.
/ Landscape rake size help #6
I have a 6 footer and HAVE used an 8 footer without a problem on a 2500DT (25hp). In your case I'd go with the 7 foot minimum and you could even consider an 8 foot.
/ Landscape rake size help #7
Bob, I just purchased a 6ft King Kutter yesterday to use behind my 28 hp Mahindra, which is 5ft wide. I have some areas pretty dense with trees and did have to watch for the extra width but it really wasn't a problem after a few scrapes. I had more trouble wanting to turn too quick and hooking it behind a tree. The rake extends behind the tractor quite a bit farther than a box blade - it's more like pulling a brush hog than a box blade.
/ Landscape rake size help #8
Bob, I think a 6' is best for what you're doing; for me (same tractor) a 7' would be better. According to my calcs, a 6' won't quite cover a 4310's tracks at 45 degrees. If you get a 5', you'll probably end up looking for someone with a sub compact to peddle it to. Another thing is- John Miller III is always right- he makes even fewer mistakes than I do /forums/images/graemlins/smirk.gif BTW- John, I'm thinking, if you have a tilt cylinder, you're better off with a single gauge wheel, rather than two- waddaya think?
/ Landscape rake size help #9
OkieNCognito,
How much did you give for your king kutter?
thanks,
Brandon
/ Landscape rake size help #10
<font color="blue">How much did you give for your king kutter?
</font>
I gave $319 for the King Kutter 72 in. rake. Atwoods (a farm supply chain mostly in Okla.) had them on sale last week - normally they sell them for around $340.
/ Landscape rake size help #11
I purchased a 7' light duty York rake to pull behind my old Ford 8N. The Kubota 3000DT I bought later on pulls the 7' rake without a problem.
As far as the little extra width goes behind the Kubota I find more positives than negitives. When angled I do not have get as close to the ditch as I would if it were a 6' rake when grooming the drive.
Randy
/ Landscape rake size help #12
Bob, I'll second everyone elses recommendations for a 6 foot or wider rake with one additional reason. The six footer will cover your tracks while angled but it will also cover your tracks when you turn. Since the rake hangs so far off the back, it doesn't track directly behind the tractor when turning. I used my 6 foot King Kutter behind my 5 foot 790 quite extensively last weekend and it was nice to be able to make turns with the rake down and have it smooth the tracks all out /forums/images/graemlins/smile.gif
/ Landscape rake size help #13
Another way to look at it. Common practice is to buy a rake 12" wider than the blade. This allows you to spread those ridges at the ends of your blade in the same number of passes as the final grade with the blade.
Thanks for all the great input. The 6Ft. rake now feels like the right purchase. I will start to review the various manufactures and to be sure, the brands you good folks have mentioned in your posts. Thanks again!
/ Landscape rake size help #15
A friend of mine priced a Befco Rake 6' Rake and it came to about 475.00. With wheels it was about 775.00. That seems a little high but I would definitly go with the wheels on the rake. They work great on my Leinbach.
~Dave~
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
INSPECTION (A65579)
INSPECTION (A65579)
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
