Rake landpride power rake
/ landpride power rake #2
I have no experience with the landpride, but do with the harley. Side by each, they look quite the same (compared them at a lawn and garden show last year). I would expect they would perform similar to each other, if bearings and gear boxes perform equally.
/ landpride power rake #4
I did look at the Landpride and thought the rakes looked fine. I own a LandPride finnish mower which has proven very reliable. I already have a Harley Pro 8 rake so was not in the market for one. I just wanted to see where things had changed. The carbide rollers definitely look like a great way to go. I have been really putting the hours on my rake the last couple of days. We've had a great warm week here in N. California and with all the grasses taking off and the Almond trees starting to blossom, I just had to get out and level up of ground before it gets to late. The rake is a fantastic addition to my small collection of implements. When my bar roller wears out, I'm going with the carbide stud roller. If I was in the market for a rake, I would look at the T-6. My little L3830 would handle it better then the 8' rake. Harley has a superb customer response and I am very impressed with the design they put into my Pro 8.
/ landpride power rake #5
Can't tell you that answer, as I don't rightly know.
Rat,
You have responded to many questions I have had. Thanks.
I have looked for the Harley at many dealers around here. None have them. Woods, Landpride and ATI are the only ones anyone local has offered.
The price on the Landpride 8' with hydraulic controls is only 250 more then the 6' Woods with manual controls. Thus the question on Landpride.
No idea if the Landpride has studs or bars on it?
/ landpride power rake #7
Landpride PR 15 series has "Tuff Studs" roller. They are "carbide enhanced. Not sure what exactly that means.
I think it would be a fine rake. Once you have used a powered rake though, there's no going back.
Rat,
A salesman told me today that an 8' power rake would over heat my L48 and for that reason recomended the 6ft. I thought I saw many posts with 8' rakes being used with under 30 pto hp? Do you think an 8' would run too slow or over heat my L48?
/ landpride power rake #9
I was told by our regional Harley rake rep. Glennmac makes all the rakes. They look alike because they are the exact same, just painted different.
/ landpride power rake #10
Does he have actual experience or is he just guessing? By the specs, the L48 should be plenty and the practical experience on the forum seems to bear that out....
I guess you can find out easy enough, all he has to do is loan one to you for a day or three. /forums/images/graemlins/grin.gif
/ landpride power rake #11
A salesman told me today that an 8' power rake would over heat my L48 and for that reason recomended the 6ft. I thought I saw many posts with 8' rakes being used with under 30 pto hp? Do you think an 8' would run too slow or over heat my L48?"
My little L3830 HST runs the Pro 8 beautifully as long as the loader is on since the thing is quite heavy. The T-8 would be a snap. I used to run it on my L48 and it did not know it was back there. I think he must be confused, very confused. Rowski has the T-8 on a much smaller tractor, the NH 2120 and he reports no issues running the rake.
I ran my Pro 8 up very steep hills on the L48 and it never got hot or ran slow, no, you would if anything be overheating the rake. /forums/images/graemlins/grin.gif
/ landpride power rake #12
All what rakes? Harley definitely does not make all the rakes. ATI makes their rakes and Landpride builds theirs. They look nothing like the Harley.
It is my understanding that Glenmac makes Harley and Woods power rakes but Landpride and ATI make their own. Your riight Rat, they do not look alike form the pictures. I have never seen one in person. It is understandable that a dealer may say something of that sort and not realize others (ones they don't deal in) exist? could happen. I have already been told by a dealer that the 8' rake would overheat and slow down my L48? I didn't believe him after reading many notes on the forum but had to double check it in case. Great and helpful input-thanks.
/ landpride power rake #14
Both Harley and ATI (called a preseeder) have videos available if you request one. Oddly, the very well built ATI didn't reperesent itself as well on the video. Actually, I did not feel the video did justice to either. It's like when you take a picture of something on a steep slope and the slope is always less impressive when viewed from a photo. Mark
/ landpride power rake #15
Pay close attention to the overall width on a 96"-wide Harley. Will it fit on your trailer? ATI Corporation's model 805 Preseeder is just under 96" in overall width. Just pull your whole rig onto your trailer. Much faster than wrestling with three-point pins and loading the rake by itself sideways!
Take a look at the peaked carbide teeth on the Preseeder as well. Much more aggressive.
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
Landhonor No Till Seed Drill (A62679)
Landhonor No Till...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
2022 EZ-GO ELITE...
