Landpride flail Fm2584/ Victory extra wide
/ Landpride flail Fm2584/ Victory extra wide #21
Hello Shaun,
Please consider the towed Hiniker 5710 flail shredder also.
It has a 6 foot cut and a constant velocity universal joint to
allow tight turns while mowing and an overrunning clutch.
  • Hiniker5710ownersmanual79202099 (2).pdf
  • Hiniker5710partsmanual79201643RevC.pdf
  • Hiniker5710shredderlit.pdf
Hello Shaun,
That looks really well built, but I was wanting something in the 7 to 9 foot range. To bad they don’t make a wider model.
/ Landpride flail Fm2584/ Victory extra wide #23
The next larger size Hiniker shredder is 15 feet wide.
/ Landpride flail Fm2584/ Victory extra wide #24
More shredders:
Brillion 12'
Kuhn 90"
Perfect 83"
Seppi 79"-108"
Rhino 15'
Dragone 78"
Rinieri TRD 79"
More shredders:
Brillion 12'
Kuhn 90"
Perfect 83"
Seppi 79"-108"
Rhino 15'
Dragone 78"
Rinieri TRD 79"
Thanks for all the shredders to look at, I really appreciate it.
/ Landpride flail Fm2584/ Victory extra wide #26
I'll toss this one out there.
I have the 78" Betstco HD (Farmer Helper) flail mower with hammers. It's a heavy piece of equipment and has done a great job mowing pastures this summer. Any small branches that fall around the edges, it chops them up. For the price, it's been fantastic. Fairly easy to adjust. Sits slightly offset. Im pretty meticulous about the maintenance. I retighten the belts and grease it before every mowing session (5 hours). They are worth checking out if you don't mind a cheaper Chinese mower.
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
KUBOTA ZD1211 ZERO TURN LAWN MOWER (A60430)
KUBOTA ZD1211 ZERO...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2014 GENIE Z-30/20N BOOM LIFT (A60429)
2014 GENIE...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-150...
