Rotary Cutter LandPride 1542 question
/ LandPride 1542 question #1
George the Beagle
Southern Maine
BX 2370
I purchased a used 1542 which was stored outdoors. I'm thinking the slipclutch should be checked to make sure it's working, but I can't figure out how to remove the plastic shroud around the pto shaft to gain access to the clutch. This has to be easier than it looks...I must be missing something fairly dumb here. Help! Thanks!
/ LandPride 1542 question #2
Mine had a port that you can pop off and get to the bolts one at a time. Mark the clutckes so go can tell that they have slipped.Mark the heads first, loosen each two turns, spin the PTO several times and make sure the clutches have slipped then tighten up the bolts back the two turns.
2011 OVERLAND TANK 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 OVERLAND TANK...
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
EZ Guide 500 Remote (A65640)
EZ Guide 500...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
Chevrolet 2500HD (A63689)
Chevrolet 2500HD...
