Tiller Land Pride RTA 1050 Tiller Question
   / Land Pride RTA 1050 Tiller Question #1
NATTYBUMPO
Traverse City, MI
Kubota L3010GST, 4WD,R1s
A friend can get a reaL good deal on a 50" LP tiller (50" tilling width). Its used but "like new" - and it really is. My problem is that I have a Kubota L3010 which is around 30 engine HP. The Land Pride catalog specs lists this tiller as having a gearbox rated for only 25 engine HP. My question is - are these gearbox ratings conservative or will the gear box blow up the first time I hitch up the PTO to my tractor??
BTW, I'm only doing a couple of gardens and a few food plots with a tiller. A few days of use at most each year. Any thoughts?? Thanks.
Natty B. /forums/images/graemlins/confused.gif
   / Land Pride RTA 1050 Tiller Question #2
Natty,
Generally when a manufacture gives a gearbox horsepower rating they will be referring to PTO horsepower. If I remember correctly the L3010 is a 24 or 25 PTO horsepower tractor so I think you will be fine for the uses you describe. Land Pride makes good equipment so if you can get a deal I would go for it.
MarkV
   / Land Pride RTA 1050 Tiller Question #3
I would think that's about the perfect tiller for your machine. I have a JD 2210. The engine is 23 hp and 17 at the PTO. I use a Frontier RT1250 49" tiller. Most manufactures have a pretty broad range or a minimum and a maximum HP rateing. On my tiller the max is 40 hp and the min. is 15-30 hp. It works like a dream on a couple of acres of wildlife food plots and small garde. Dave
Thanks guys. Any other reports on LandPride tillers out there??
Also is it necessary that a 3-pt tiller be as wide as the tractor tire width??
   / Land Pride RTA 1050 Tiller Question #5
</font><font color="blue" class="small">( is it necessary that a 3-pt tiller be as wide as the tractor tire width )</font>
In my opinion, it is certainly preferable, but it is not necessary. Many of the tillers can be offset to cover your tracks on one side. I used a 40" tiller on a B2710 (54" outside tire width) by offsetting the tiller to cover my right track.
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2009 Honda Pilot AWD SUV (A53424)
2009 Honda Pilot...
2014 CS&P  BLENDER (A55745)
2014 CS&P BLENDER...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
