Land Pride cutter replacement blades.
   / Land Pride cutter replacement blades. #1
mddorange
Elite Member
Guin, AL
2014 Kubota L3200 DT w/LA524 FEL, Loaded rear tires, LP RCR 1860 5' Cutter, LP RTA 1258 5' Tiller, LP PFL 2042 Pallet Forks w/60" Extensions, KK BB60 Box Blade, KK PHD-12" Post Hole Digger
I have replaced a few broken blades on my LP RCR1860 cutter. Everyone I talk too says that LP blades are the most expensive. I am look for a suitable replacement blade that is cheaper. Is there such a thing out there?
   / Land Pride cutter replacement blades. #2
Would like to see what you find out... (aka. bump!)
   / Land Pride cutter replacement blades. #3
I had good luck with Land Pride blades sold on eBay by GA-EQUIPMENT. I don't know if the model I use 890-204C, 890-171C, 890.375C fits yours.
   / Land Pride cutter replacement blades. #4
I have to double check my model... I was thinking my blades were 820-067C (1/2"x3"x24.5")
   / Land Pride cutter replacement blades. #5
I've bought blades for a different mower from GA Equipment off Ebay, and had good luck with them as well.
   / Land Pride cutter replacement blades. #6
...GA Equipment off Ebay...
It looks like full price on the ones I looked up. I guess mower blades and cheaper aren't what you want to combine...
The problem is that Ga-Equipment only has finish mower blades, "890-", from Land Pride and I need cutter blades, "820-".
   / Land Pride cutter replacement blades. #8
Agri Supply has blades and dimensions. Call them to see if they can match your blade.
SearchCenter
Alternately, there is a shop that makes automotive springs local to me that also makes cutter blades. If you have such a shop locally it might be an option.
   / Land Pride cutter replacement blades. #9
Oops... my mower is RCR1560... I'm going to try and take one off.
I couldn't find anything out there that was cheaper and was comparable so I bit the bullet and bought Land Pride blades.
TAKEUCHI TS60R SKID STEER (A51246)
TAKEUCHI TS60R...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
2017 International Prostar Sleeper Truck Tractor - Cummins ISX 15 Engine - 10 Speed Eaton Fuller (A53472)
2017 International...
2239 (A51244)
2239 (A51244)
