Land Pride cutter replacement blades.
   / Land Pride cutter replacement blades. #1
mddorange
Elite Member
Guin, AL
2014 Kubota L3200 DT w/LA524 FEL, Loaded rear tires, LP RCR 1860 5' Cutter, LP RTA 1258 5' Tiller, LP PFL 2042 Pallet Forks w/60" Extensions, KK BB60 Box Blade, KK PHD-12" Post Hole Digger
I have replaced a few broken blades on my LP RCR1860 cutter. Everyone I talk too says that LP blades are the most expensive. I am look for a suitable replacement blade that is cheaper. Is there such a thing out there?
   / Land Pride cutter replacement blades. #2
Would like to see what you find out... (aka. bump!)
   / Land Pride cutter replacement blades. #3
I had good luck with Land Pride blades sold on eBay by GA-EQUIPMENT. I don't know if the model I use 890-204C, 890-171C, 890.375C fits yours.
   / Land Pride cutter replacement blades. #4
I have to double check my model... I was thinking my blades were 820-067C (1/2"x3"x24.5")
   / Land Pride cutter replacement blades. #5
I've bought blades for a different mower from GA Equipment off Ebay, and had good luck with them as well.
   / Land Pride cutter replacement blades. #6
...GA Equipment off Ebay...
It looks like full price on the ones I looked up. I guess mower blades and cheaper aren't what you want to combine...
The problem is that Ga-Equipment only has finish mower blades, "890-", from Land Pride and I need cutter blades, "820-".
   / Land Pride cutter replacement blades. #8
Agri Supply has blades and dimensions. Call them to see if they can match your blade.
SearchCenter
Alternately, there is a shop that makes automotive springs local to me that also makes cutter blades. If you have such a shop locally it might be an option.
   / Land Pride cutter replacement blades. #9
Oops... my mower is RCR1560... I'm going to try and take one off.
I couldn't find anything out there that was cheaper and was comparable so I bit the bullet and bought Land Pride blades.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Komatsu 330 Excavator (A51573)
Komatsu 330...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2009 Chevrolet Trail Blazer SUV (A51694)
2009 Chevrolet...
