Box Scraper Land plane help .
   / Land plane help . #11
saw the thread title and just wanted to check to see if you landed safely yet.........
   / Land plane help . #12
Looking for a little info on a land plane . I have a 40hp 4x4 new holland . What is the largest plane y隱浜l recommend? Will just be used for maintaining my 1/4 long driveway.
10ft land pride is far too large in my opinion. The absolute max I would even consider is 9ft. and that's pushing it awful far on a gooood deal. I've got a Woods GSS72P w/ scarifiers which is 72" and quite frankly I don't think I'd go any bigger than 84". I have not needed the scarifiers unless ripping up dirt.
I use mine on my driveway which is about 950ft. long and leveling dirt. I just moved and leveled over 80 ton of dirt for a guy and he just called to have me come back for some more. Lol
Keeping a good crown will significantly reduce driveway maintenance while reducing the need for more gravel. I pull the gravel in from the edges of my drive every year with my rear blade. Then build the crown back up with the blade. After doing this I run down one side with the land plane and back down the other to mix the gravel and fines back together. Works like a charm and haven't had any need to add gravel in 5 years. Nothing beats having a land plane for your gravel drive. Another thing I壇 highly suggest is a hydraulic top link. If you've got any further questions, feel free to ask.
   / Land plane help . #13
I have a mile long driveway. Straight as an arrow and composed of: gravel, sand, silt & volcanic ash. After the spring rains - it hardens up like concrete. Any summer "land planing" requires that I also use the scarifiers. I have a Land Pride GS 2584 @ 800#. There ARE times I wish it weighed around 1200#.
The LPGS will smooth out the few pothole that develop during the fall to spring season. If more aggressive action is required - then my Rhino rear blade is used. My land plane does not move that much material - horizontally. It certainly WILL NOT create a crown on my driveway. I totally rely on my Rhino rear blade for crowning and any major modifications. Rhino 950 - 96" - 1050#.
I would suggest the heaviest seven foot LPGS you can find and with scarifiers( if your driveway "hardens up" in the summer). If you should find a heavy six footer that would be OK also.
The idea that the LPGS MUST be wider than your rear tires is a pure fallacy. Come on folks - we are grinding up the surface of a gravel driveway. A few tractor tire tracks is not going to defeat the project. I work to maintain a reliable driving surface - not a pool table.
Like others have mentioned - a hydraulic top link is a real joy to use when dealing with land engagement implements.
   / Land plane help . #14
I agree. This implement really isn't that useful when trying to build a crown. The only way I could honestly see this being possible is if you could adjust your skids further down on one side than the other or a hydraulic sidelink. I've tried adjusting my sidelink and it honestly wasn't worth a ****. I'll stick with my blade for crowning.
   / Land plane help . #15
My 6’ EA land plane behind my 59hp 4x4 tractor on my steep, curvy road is all the tractor can handle at times. Adequately covers driveway 12-20 wide. Both crown and bevel.
It might not matter to you but stays on my tractor at times as counter weight for loader work. A wide implement would be awkward.
   / Land plane help . #16
My Rhino rear blade @ 1050# is my counter weight on the 3-point. I can't remember a time when having the 96" wide blade on the rear has been a problem. My property is - more or less - wide open. Stands of P. pine and acres of bunch grass.
I guess if I ever needed to get in and among the pines - turn the rear blade 90 degrees and lock it down.
I could use my LPGS. It's got the weight ( 800# ) but it's also has a massive foot print. I could see getting "locked in" in a stand of pines with the LPGS on the 3-point.
   / Land plane help . #17
So...... Strummer. Have you narrowed down your choices. Post a nice picture when you get the LPGS.
   / Land plane help .
Probably going to just borrow my buddies land plane . He has a 8 or 9 ft Armstrong. If I like the way it works for me I will buy one . If I don’t like it I might go the blade route .
   / Land plane help . #19
THAT is the best of all worlds. You will get to see exactly what a LPGS can/can not do. Fact - the LPGS is perhaps the easiest land engagement implement to learn/use. The rear blade - not so much. The rear blade will do many, many tasks but it DOES take quite a bit of practice to get good.
I've been using a rear blade since 1982. I would say that I'm pretty good with it. However - there are still those times when I have to spend addition time/effort to get things right.
A suggestion - if your driveway is crowned. Don't drag the LPGS right down the center. While the LPGS will not create a crown - it surely can reduce/lower the existing crown. Best approach - up one side, back down the other. The inboard edge of the LPGS only just reaching the center of the driveway on the passes in each direction. This is why most suggest that you purchase a LPGS that is only half as wide as your driveway.
Anyhow - have fun, good luck.
2018 Deere 323E (A53317)
2018 Deere 323E...
UNUSED WOLVERINE TDB-11-78W 78" BUCKET (A57193)
UNUSED WOLVERINE...
2013 Ford E-250 Cargo Van (A56858)
2013 Ford E-250...
2012 Volvo BL70B (A53317)
2012 Volvo BL70B...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
Bush Hog RZ60 (A56469)
