Box Scraper Land Plane for Ford 1100...
   / Land Plane for Ford 1100... #1
TIDE HSV
Huntsville, AL
Ford 1100
I have an extensive graveled parking area plus drive. I've recently had the entire area re-graveled. There is one slope connecting the parking area and the drive. My contractors advised purchasing a grader-scraper for the gravel, which tends to migrate downhill/downstream over time. The little Ford supposedly develops around 13 HP. I'm looking at the Land Plane, now owned by John Deere, I think, and the Land Pride scraper-grader now owned by Kubota. The Land Plane is available only in 5'. The Land Pride has a 4' model, which is something like 430 lb+. The 5' Land Plane is around 70-80 lb heavier. The Land Pride is about $300 more, as priced around here. The 5' Land Plane requires a minimum of 18 HP. The 4' Land Pride says 20 HP minimum. My landscaping contractor says that the Ford will handle either easily, just moving gravel. Any experience out there?
   / Land Plane for Ford 1100... #2
I had a Ford 1100 in many ways I wish that I still had it. For moving gravel I agree with your landscaper. IMO
Thanks! Did you have a box or something similar you moved gravel with it?
   / Land Plane for Ford 1100... #4
All I had was a dual hydraulic frontend 4' dozer blade and an old weighted down car hood to move and level gravel/sand for the 150' of driveway I managed then. It took forever, but it worked. I would have liked to have had a rear blade or boxblade for it back then.
I checked tractordata.com. The 1100 has a lifting force of 881#’s at the 3ph. I had appropriately sized Woods tiller and rotary cutter that it handled really well. If I remember correctly both were ~40”.
It was a great little tractor. I traded it in for my current tractor. Replacement parts may be hard to find nowadays.
Good luck have fun.
Thanks. That's helpful. My tractor isn't fitted with the front end, so I have to use the 3 pt. At 881, it sounds like the 70-80 lb lighter of the 48" Land Pride (Kubota) may be really important. It's just not the steel; it's the extra gravel the 5' would pick up. Here are some pix of my back parking area and drive to give an idea of the job... 20190914_122854[1].jpg20190914_123123[1].jpg
   / Land Plane for Ford 1100... #6
TIDE- You have a really nice place.:cool: Unless there is a balance issue with your tractor-blade setup I really do not think the extra blade length matters in this case; all you are lifting is the blade. You are moving the material not lifting it. How much you move is blade height dependent if I understand you correctly. You could make it work with the 13HP, especially in 4WD in lower gearing. If I remember correctly my gear driven 1100 had 3 ranges with 5 gears forward. Just my $.02.
Thanks! I was checking several nearby dealers and almost didn't call the one furthest away, which was still only around 60 miles. Boy, am I glad I did. Not only were they $200 under what my landscaper could get for a dealer price, I found out that there's a GS0548 model which only weighs 300 lb, with thinner steel. That was even cheaper by another $150 or so...
BTW, the gearing is as you remember it but, without the front bucket, only 2WD is available...
   / Land Plane for Ford 1100... #9
It really pays tp shop around for attachments. Like you I am 23 miles from any population center; much farther for decent tractor stuff. My original family owned NH dealership went out of business due to market forces. They were ~20 miles away and would do home service as needed. I still miss them.
I really do not think that you will have any problems with 2WD for what you intend to do.
I'm in Huntsville, AL, so in the middle of 6-700K people. It's just that the local dealers understand nothing but MSRP. I just bought an X370 JD riding mower from a dealer about 30 miles away. The "local" dealer wanted MSRP - period. The salesman even told me he'd sold two that morning. (IOW, don't even try bargaining.) The dealer I bought from sold it $1000 cheaper and delivered it - free. I guess it's just one of the problems of living in an affluent area. OTOH, there's this - US News, so go figure...
SAKAI SW502S-1 SMOOTH DBL DRUM ROLLER (A51246)
SAKAI SW502S-1...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
