Land plane build and new yard.
   / Land plane build and new yard. #1
STERLING351
Mahindra 2555 cab, Mahindra 4500
So i have been wanting a land plane for a while now for finish work. I have a Cat D4E for clearing land but to be honest i am no pro at the finish work and grading. So I built a land plane to help me with the finish work. The skids are made of some C-channel I had left over from a project. The tubing is all 2" tubing i get for free. The angle iron is 6"x4"x 5/16' that was left over from a project as well. The blades are 7' long and 1/2" thick. The skids are 5'6" of useable space. Over all I like it, if i were to go back and change some things I would not have made my cutting blades so vertical and I would have made the skids longer. This is a good size to be used with my Mahindra 2555, and i believe it weighs around 900 pounds.
The backyard is not 100% complete but its getting there. This area used to be full of mesquite trees and had quite a elevation difference. The area is now much more smooth with a gradual slope to lessen the erosion issues. The purple post are markers for my septic system sprinkler heads. I threw out some annual ryegrass and bermuda seed this evening because we are expecting rain over the next few days. I plane to come back early spring and further focus on leveling but for now I have a new fence line that wont build its self and clearing another 6 acres of mesquite to convert to pasture.
more pics
and more
   / Land plane build and new yard. #4
Seems to be doing a fine job. Sure flattens the land.
   / Land plane build and new yard. #5
On mine I made the top link so that it would flex and the rear blade flows with the ground. I also made the shoes longer in back and as I raise the 3 pt it cleans out smooth and not leave piles at the end of the run. Watch turning when down it well bend the lower link mounts.
   / Land plane build and new yard. #6
I need a "like" button. I've thought about designing one with a method to adjust the blade down or up just a bit, relative to the bottom of the skids.
The front blade is adjustable. Thats what the bolts are for on the front blade. It has the ability to got 1/2" below grade to remove more material.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A55302)
2016 RAM 5500...
2016 Chevrolet Malibu Sedan (A53424)
2016 Chevrolet...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
