Land plane build and new yard.
   / Land plane build and new yard. #1
STERLING351
Mahindra 2555 cab, Mahindra 4500
So i have been wanting a land plane for a while now for finish work. I have a Cat D4E for clearing land but to be honest i am no pro at the finish work and grading. So I built a land plane to help me with the finish work. The skids are made of some C-channel I had left over from a project. The tubing is all 2" tubing i get for free. The angle iron is 6"x4"x 5/16' that was left over from a project as well. The blades are 7' long and 1/2" thick. The skids are 5'6" of useable space. Over all I like it, if i were to go back and change some things I would not have made my cutting blades so vertical and I would have made the skids longer. This is a good size to be used with my Mahindra 2555, and i believe it weighs around 900 pounds.
The backyard is not 100% complete but its getting there. This area used to be full of mesquite trees and had quite a elevation difference. The area is now much more smooth with a gradual slope to lessen the erosion issues. The purple post are markers for my septic system sprinkler heads. I threw out some annual ryegrass and bermuda seed this evening because we are expecting rain over the next few days. I plane to come back early spring and further focus on leveling but for now I have a new fence line that wont build its self and clearing another 6 acres of mesquite to convert to pasture.
more pics
and more
   / Land plane build and new yard. #4
Seems to be doing a fine job. Sure flattens the land.
   / Land plane build and new yard. #5
On mine I made the top link so that it would flex and the rear blade flows with the ground. I also made the shoes longer in back and as I raise the 3 pt it cleans out smooth and not leave piles at the end of the run. Watch turning when down it well bend the lower link mounts.
   / Land plane build and new yard. #6
I need a "like" button. I've thought about designing one with a method to adjust the blade down or up just a bit, relative to the bottom of the skids.
The front blade is adjustable. Thats what the bolts are for on the front blade. It has the ability to got 1/2" below grade to remove more material.
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
Metal American Flag Rooster Statue (A55758)
Metal American...
2018 Chevrolet Malibu Sedan (A55758)
2018 Chevrolet...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2006 Kubota M8540 (A53314)
2006 Kubota M8540...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
