land pland grading scraper
/ land pland grading scraper #1
Lowcountry Rebel
Ravenel S.C.
TYM 603
My wife was getting tired of all the bumps and side to side rocking while driving down our gravel driveway- about 1/3 mile from the pavement to the house, so I bought a LPGS- land pride brand 7'.
I set the rippers 1.5" deep and made a pass down 1 side and back up the other, pulled the rippers even with the blade and made another pass in each direction, then back drug it with the loader. Man- what a difference. I'll probably smooth it again tomorrow after work.
Now I have another 1/2 mile of road to do to get to the back of the property, we are putting a greenhouse back there to use our pond for the water supply.
Really glad I chose this over a box blade. It will make smooth roads an easy project.
/ land pland grading scraper #2
Not much of a learning curve needed with a land plane like a grader blade or BB. They make it some easy work.
/ land pland grading scraper #3
Curious, why back drag with the loader? You should have a very good surface with just the LPGS. If you want it even smoother, then use the LPGS in reverse. Makes the finish very smooth and even. ;)
/ land pland grading scraper #4
If you were looking to pack it down after using the LPGS - just go back/forth with your tractor.
I made a few more passes yesterday and tried using the LPGS in reverse- worked pretty good like that. Thanks for the info. The road is pretty smooth now.
/ land pland grading scraper #6
Just be careful back dragging with the loader, it’s easy to bend your hydraulic cylinders that way.
/ land pland grading scraper #7
Just be careful back dragging with the loader, it痴 easy to bend your hydraulic cylinders that way.
Yes indeed, I have seen several posts here on TBN where this happened. I myself have done it countless times with no problem....... as they say, "All good things must come to an end". I just replaced 2 cylinders damaged by back dragging. I bent both rods and cracked both gland nuts.
/ land pland grading scraper #8
If you need to use the loader to back drag, have the bucket flat or tilted forward only a small amount. Less than 15* I believe is the recommended safe amount of tilt recommended for most loaders. ;)
2015 TECUMSEH BD (A67714)
2015 TECUMSEH BD...
Kelly-Creswell Model C Walk Behind Paint Striper (A66734)
Kelly-Creswell...
2010 Rhodes AS3575-3 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A66736)
2010 Rhodes...
2009 PETERBILT 365(INOPERABLE) (A67714)
2009 PETERBILT...
ROOF RACK (A68842)
ROOF RACK (A68842)
KUBOTA ZD1511 ZERO TURN LAWN MOWER (A65057)
KUBOTA ZD1511 ZERO...
