Rear Blade Land Leveler/Grader Blade/Land Plane
   / Land Leveler/Grader Blade/Land Plane
The GS isn't designed for moving material really. It will fill to the top and spill excess over the back. To cut down high spots and fill low ones with what is cut off you can have the blades even with the bottom of the skid shoes. Or to get an aggressive dig/cut drop the blades below the skid shoes.
Putting the rippers down just enough to dig in and break up the top of the packed material with the blades set even with the skid shoes should ensure a good consistent level of material in front of the blades to deposit in low spots.
The weight is fine. Having the rippers is a big benefit that (IMHO) negates the need for the added weight.
Thanks, very helpful
   / Land Leveler/Grader Blade/Land Plane #22
Now that I got remotes and top n tilt installed on my tractor I plan to hook up the rear blade and put a good 4 degree crown on the road. Once that is set the LPGS will be perfect for monthly maintenance. Couple passes to refinish and done. As opposed to letting it go then having to spend hours with a box blade.
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
Heavy-Duty Ratchet Load Binders & Chains Set (A53117)
Heavy-Duty Ratchet...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
2016 Jeep Wrangler Unlimited SUV (A55853)
2016 Jeep Wrangler...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
FAKE (A52472)
FAKE (A52472)
