boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
beyond having a crown, and then ditches to carry the water away. so no water stands on the road it self and runs off the road, and into ditches were it is carried away. so the road is kept dry.
you pretty much have the tools already with the belly blade, rear blade, and box blade.
i am wondering if you are compacting the drive good after you mess with it. (1 tire width at a time) and how ever much weight you can load up on a tractor. so weight of 1 tire width compacts the road. if you can attack at different angles to help lock the gravel on the surface you should get a better compaction.
trying to stay off of it when it is "really wet" as much as possible suggested, until you get drive compacted, and it may take a couple rains and just as it is about to dry good. get out there and run over it to compact it.
internet search for "forestry roads" should return 5 or so descent websites that goes over roads. that most folks on their driveways can use nice and easily.
land plan / grader scraper there are some DIY versions out there, along with some different styles that are geared to ATV / UTV / lawn mower / and even trucks out there.
though what you have already looked at most likely better choice, in wanting to "sift" the rocks and dirt. so rocks come to the top and dirt falls down.
with all above said. sounds like you still have some water on the road and in the ditches beside it. causing the clay to become slip n slide when ever it gets wet, letting your rock vanish into the mud. if ya need to build up the areas to help shed the water do what ya gotta do. to get the water off the road and then get it sent down the ditches.
