land grader ideas/ plans?
   / land grader ideas/ plans? #11
   / land grader ideas/ plans? #12
Either do this as is, or build a trailer assembly behind it, and you could use 3 pt implements.
   / land grader ideas/ plans? #13
This company has several products.
Dirt Dog Manufacturing >> ATV Equipment
The design is simple. If you had slightly smaller square tubing on the left wheel mount and several drilled holes, you could adjust that side for tilt to crown the road.
now were getting close to what i had in mind... tires and the abilitiy to lift the blade back up and take another cut... what happens if i hit something unmovable? any kinda blade rollover like a snow plow?
   / land grader ideas/ plans? #15
I don't think you need springs. If it hits something, it will either slide sideways or hop over the obstruction. If you want them, you could do something like this.
   / land grader ideas/ plans? #16
I'm always surprised by how fast people in videos on ATV's are towing graders. If they snag a rock or root, there will be wreckage spread for 50 yards.
Bruce
   / land grader ideas/ plans? #17
Amen to going slow. You could just use a 1/4" bolt in the hitch as a sort of shear pin.
   / land grader ideas/ plans? #18
look for david bradley attachments you can pull them behind.
   / land grader ideas/ plans? #19
In days of your many drawbar hitched machines had a spring loaded release hitch that worked well when the immovable object was hit.
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
1992 BYQ Boat and Trailer (A56859)
1992 BYQ Boat and...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
2013 International TerraStar Enclosed Service Truck with Liftgate (A56858)
2013 International...
Toro Multi Pro 5800 (A55758)
Toro Multi Pro...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
