Laminate Flooring?
/ Laminate Flooring? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
A few questions for you good folks who have installed Laminate flooring,how well does it hold up?What name brand did you buy?My wife and I are looking at installing the quick-step brand name,any thoughts good or bad?Thanks,coobie.
/ Laminate Flooring? #2
have it in place for about ten years now. not sure of the brands, but one section of it is in our basement over a sub floor and it still looks great.
hints
1. get the tool kit, helps with the install.
2. order any baseboards/molding at the same time so that the color styles match
3. if installing over a concrete floor take a piece of plastic on the floor if there is condensation then it will buckle your floor.
4. take your time on your first row its the hardest, also make sure the groove is always clean, the smallest amount of sawdust will keep it from locking.
5. plan where your first row will go, its easier to make it fit under a baseboard instead of trying to snap it under a baseboard.
just remember its a floating floor leave a gap all along, if its in a kitchen or bathroom you may have to silicone your edges.
/ Laminate Flooring? #3
I'm a plumber. I HATE it. I have had small mishaps that cost me thousands. If it had been any other type flooring, it would have been a mop and go.
/ Laminate Flooring? #4
Everything forgeblast said.....I'd add I used the manufacturer's (Pergo) foam underlayment.
Pergo has a particle board base. If it gets wet it will be ruined. Replacing sections that get wet for me is not an option since my floor is glued together.
I installed mine about 10 years ago and it looks as good as it did the day I installed it.
I ordered my floor through DIYflooring.com
/ Laminate Flooring? #5
not familiar with that brand but I have installed thousands of sf of different brands...and the one thing I will say is stay away from the cheaper brands...
also...if you have a lot of (door) openings to install through/around...it will pay you to rent a jamb saw...
/ Laminate Flooring? #6
I put it over the floor electrical heating cable in our living room. It is there for 5 years and holds up great.
Not sure of a brand, it was coupon at Costco, they have a nice selection of finishes.
/ Laminate Flooring? #7
Built a new home 3 years ago. I put hardwood and tile in all of the home except for the finsished room over garage. Used some pergo brand and carpet in that room.
Bottom line is we much prefer the hardwood. We do not care for the hollow sound of the pergo, holding up well though.
They make several qualities of the foam pad that goes under the pergo. We were advised to spend the extra for the better pad so we did. I also got the installation kit and it did make the job easier.
/ Laminate Flooring? #8
We put down our laminate flooring about 4 years ago. We got a bunch of cheap stuff at HD (I think it was a Shaw brand, but I'm not sure). We figured that we could use it for now and upgrade the flooring later.
Install was not too bad - I'm definately with the crowd that saws get the install tool kit. Also, ours was advertised as "snap together" but it worked alot better as "hammer together"!
It has held up very well, with the exception of a few places where the kids spilled something on it, didn't clean it up, and it sat there and soaked in. Now there are little swollen areas at the joints. However, these are just a few spots, and it has otherwise held up well daily wear and sweeping/mopping.
Of course, neither I nor my wife like to sweep or mop, so it's probably only been mopped about twice a year!
I would definately use laminate again. However, I've seen expensive laminate that rivals the cost of hardwood, so I'm not sure I would spend as much or more on laminate as opposed to hardwood.
Kays Suppy Plumber Man (Reed? maybe) - what happened with laminate that has caused you such trouble? Is it moisture related?
Good luck and take care.
/ Laminate Flooring? #9
I am fixing to lay real 3/4 " read oak, i am buying 3 1/4 boards for less than $2ft, this is not a deal or contractor price but the everyday price. My brother in law used it in his whole down stairs (about 1700ft) so i know what the product looks like, its not filled with knots or cracks. Anyway in looking over the last year at everywhere from online to lumber liquadators to lowes this is as cheap as you can find it. I have also seen some of the american woods, not rain forest exotics, for around $6 sq/ft uninstalled!!! NOw i will put my unfinished wood in myself and then finish it my self (we dont like the grooves in the prefinished wood) and can finish it with 7 coats of poly for around or less than a $1ft so i will have less than $3ft in it. Even if i paid to have it done i figure it would still be $5 ft i have no idea why some one will buy an engineered oak laminite for $4-5 ft. They say you can refinish it once for the good stuff but its still thin and i know when i refinished the other 1000 feet or so of Hardwood in my house that sometimes you go deeper unintentionally and sometimes on purpose to get out an inperfection, id had to sand down to the MDF on that stuff.
But back on topic, my cousin put it in his house with the help of his dad, they are not really handy and it looks good, there are a few details like they did not vary the boards so you have a consistant pattern of boards in the floor but most will not notice it. They have 2 kids one 7 and the other 9. It looks almost as good as the day they put it in 3 yrs or so ago. It has a few scratches from there dogs ( have 3, 2 yippies and a big bird dog) but not as bad as real wood at my house. No visible swell and im sure the kids spilled on it, they may have wiped it up fast though?
For the money i still would go to lowes and buy the solid 3/4 prefinished oak that they sell on sale for $2.78 sq/ft and use a 10% off coupon and have real wood with the benefit (so they say) of that factory UV cooked coating that they say is harder than your onsite floors. That said i took a few things at lowes and slowly dragged them with little pressure on those 3/4 oak gunstock or whatever prefinished wood samples they had out and they seemed to scratch just as easy as my on site floors.
/ Laminate Flooring? #10
I put laminate from Sam's Club in my house about 6-7 years ago and love it. The stuff seems indestructible. I threw the scrap in the back of my truck when finished and decided to just leave it there and see what happened to it. After about 2 months of being exposed to the elements it was still good as new. Can't recall the brand, but it was a breeze to install with no special tools.
/ Laminate Flooring? #11
We installed Formica brand laminate flooring in our house about 10 years ago. At the time it was the only brand we found with a 25 year warranty that covered water damage. It required glue; some of the new ones don't. It has held up very well.
/ Laminate Flooring? #12
just as an fyi, In my coop i have laminate down under the roost board (called a poop board) that i scrape into a bucket to compost once a week. the laminate is holding uup well there.
/ Laminate Flooring? #13
Reply to question, Yes water. I have had an issue with some of the new faucets. They are trying to be lead free. They use plastic supply lines made into the faucets. The first models came with plastic ferrels to use if you had to cut the extremely long supply lines that are made onto the faucet. Well, I was one of the first to find out the plastic ferrels would pull off the plastic supply lines if cut. Even though we were on the site when they popped, it still cost me $1600 to replace a room of flooring that wasn't wet over 15 minutes. Now we have to roll up 30" of plastic line under every sink. It looks like $@%^*(*^%#.
/ Laminate Flooring? #14
FWIW, we're getting ready to do several rooms worth of insurance-covered floor covering work due to a plumbing disaster that happened while we were away for a few days (Murphy's law strikes again). Wife wanted wood, but I didn't like that idea because it's all high wear areas and is going down directly over concrete. After looking over what's available for water/damp resistant flooring in our very high traffic kitchen/breakfast nook/mud room area, we've settled on random-laid 3-1/2" x 24" wood-grain finish 3/8" thick porcelain ceramic tiles. I didn't even know they made this stuff. We looked at several sample floors done with this stuff, really liked the look, and it's practically indestructible as far as wear and moisture go. Comes in several kinds of wood grains and colors, and runs around $4 per sq/ft, not much more than good laminate, although a pro installer is needed so labor is higher. These will be going down directly on a concrete slab. Our tile contractor thinks wood plank look porcelain tiles are a great idea, says they are hands-down more preferable than laminate or solid wood if the flooring is going directly onto concrete, and his customers love them. They also come in wide planks, too, but we liked the look of the narrow version. We'll see how they work for us.
For concrete slab floors on or below grade, this stuff might be worth a look before you commit to any type of "floating" laminate or wood flooring that has to be put down over a moisture barrier and refinished every few years.
/ Laminate Flooring? #15
Sign me up for "I hate it" too. Our elderly dog took leak on it and it buckled. I think mine was Armstrong brand. The dealer said if you wipe up a spill within 15 minutes all is well. That means never leave home.
Also it is LOUD. Drop a dime on it and it sounds like a snare drum.
I'd rather have a dirt floor.
Lee
/ Laminate Flooring? #16
I've installed quite a bit of it and believe that you get what you pay for.
The warrentee's are worthless. While the companies will honor them, the fine print is just replacement. So if you have a board in the middle of your floor that needs to be replaced, the manufacturer will give you a new piece of flooring. Now what? Somebody has to replace it. They can either cut out the bad piece and modify the new one to fit, or remove all of the floor to get to that one and then re install the floor. Who pays for that? You do. Labor is not covered under any warrentee that I've ever come across, nor wil I do warrentee work. If you hire me to fix it, I'm going to charge you for my labor.
Several things that really make a huge difference in the final floor, and how it ends up.
First, make sure that the sub floor is smooth and flat. It sounds obvious, but very few slabs are totaly flat. If you put water on the slab, you would see that puddles appear all over. Depending on the size of the low areas, and how bad the difference is, I fill them with floor leveling material. It mixes up watery and you just pour it out, then feather the edges. Simpe, kind of price, but time consuming.
Making sure the slab is dry and you don't have moisture coming up is critical. Tape a piece of plastic to the floor for a week. Pull it off and see if there is moisture under the plastic. If so, you will have that same level of moisture under your wood. If so, your wood will fail and come apart. if its dry, then you are good to go.
Unnderlayment is critical. I use a felt type underlayment. Right now, I find that Lowes has the best deal and the best product. There is no other type of pad that I would put under a floating floor. I don't care what the cost increase is, it's cheap compared to the live of the floor.
I like to take off the baseboards, then install the flooring and then inststall the baseboards, or new baseboards. I hate quarter round.
Good luck,
Eddie
/ Laminate Flooring? #17
I bought 700 sq of the sam's club stuff 3 years ago. It has the foam underneath it. I thought for sure it was going to buckle and look like crap because I found after removing carpet that I had some very un even floors. 3 years later with 4 kids under the age of 10 and 2 dogs it still looks great. I did have to put one or two finish nails in the places where the floor was un even.
We are however careful to clean up any spills and the entry way is tiled for taking off boots.
/ Laminate Flooring? #18
Just a note you cant put wood over concrete (solid wood). Well let me rephrase that, you should not put wood over concrete. You would have to glue it down creating a mess or put treated 2xs or something then put plywood down then have a moisture barrier to be able to nail the wood down, and if you glue you cant have a plastic barier as the glue will be on plastic not concrete. I would never do it, this is where these floating laminits with a quality foam/plastic vapor barrier are really used i guess? Tile would be my choice though.
/ Laminate Flooring? #19
That's a fact, at least in our case. Our Mohawk laminated floor is just over 3 years old. I learned the manufacturer (Mohawk) will not reply to any questions; except to tell you that you have to go through your dealer. And the dealer who installed ours was bankrupted by a lawsuit they lost.:laughing: Overall, I suppose we aren't too unhappy with it, but I'll bet we never have anymore laminated flooring installed.
/ Laminate Flooring? #20
just to expand on this a bit...for those that do not do a lot of remodeling...be sure to use a utility knife and cut the paint/calking along the top of the baseboard befor removing to prevent tearing or peeling the sheetrock paper/paint... when replaced a thin bead of calking will restore the finished look...
another trick is to use pliers and pull the old nails through the back of the baseboards to prevent checking...
Another option if the floors are smooth and flat is using a jamb saw...this tool can be set to cut the bottom of baseboards (and door casings etc) to allow just enough clearance to slide the laminate under to give a professional looking finish without having to remove the trim....
a "jamb saw" (for anyone tht is not familiar) is a horizontal circular saw that has an adjustable base that is on rollers...
for those that only need to cut a few door casings an offset flat saw (hand) can be placed on top of a piece of laminate to guage the height of the cut off the floor...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Colombo CTA 6500 (A64119)
Colombo CTA 6500...
2001 Wellcraft Boat w/ 2000 Boat Trailer, (A61574)
2001 Wellcraft...
Caterpillar 970F Wheel Loader Parts and Service Manuals (A63117)
Caterpillar 970F...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
