lack of hydraulic pressure
   / lack of hydraulic pressure #1
rich3930
atwater,ohio
john deere 510 backhoe
john deere 510 backhoe, im lacking pressure on some of the cylinders on the hoe only. the front bucket works ok,
   / lack of hydraulic pressure #2
Everything else is OK? Steering, R/F shuttle? And it's just a problem with "some" of the hydraulic functions on the hoe?
If I had to take a "stab" at the problem - I'd be looking at the multi-function valve body for the hoe. Could be debris or inline gunk that's causing a loss of functional pressure in one or more of the valve circuits.
Isolate the hyd circuit to the valve and check the flow.
Good luck.
AKfish
thanks for the advice
   / lack of hydraulic pressure #4
Which functions on the hoe are weak? Each function has it's own relief valve. You could have a weak relief valve or two. Did the functions that are weak, all get weak at the same time? On those functions, do the cylinders leak down quickly/ If so you could have blown seals in the cylinders.
1999 CAT TH63 (A50123)
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
2025 CFG Industrial M-DRG (A50123)
2025 CFG...
197711 (A51244)
197711 (A51244)
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
