LA513 vs LA723 loader
/ LA513 vs LA723 loader #2
The 723 will lift 500 pounds more to a slightly greater height and also has a greater breakout force. Don't know the specs offhand but definitely a worthwhile upgrade.
/ LA513 vs LA723 loader #4
The 723 has greater dump and roll back angles too due to the linkage at the bucket. Makes a big difference when using it.
/ LA513 vs LA723 loader #5
Builder,
The model numbers designate the capacity in kilograms - 510 kg = 1120 lbs
and 720 lbs = 1580 lbs. The "3" is the third generation
The LA513 is not compatible with a backhoe so if all you want is a light loader, that is the one to buy.
The LA723 has much heavier weldments and larger bore cylinders - a better choice for heavier work and if your wife OKs the backhoe, you are ready to load the trailer!
Have fun!
/ LA513 vs LA723 loader #6
Yankeclipper - Can you explain why the LA513 can not be used in conjunction with a backhoe?
/ LA513 vs LA723 loader #7
The loader subframe brackets are lighter/lesser and not compatible with the subframe mounted Kubota backhoe.
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
Sioux Mineral Feeders (A66408)
Sioux Mineral...
Firestone Bolt On Duals 14.8-38 (A65640)
Firestone Bolt On...
Red Oak Boards (A65640)
Red Oak Boards...
