LA482 loader valve
   / LA482 loader valve
Kubmech, Thanks for all your help..........the dealer told me there is a power beyond kit that goes on the loader valve, does he know what he is talking about?
Jack
   / LA482 loader valve #12
Sorry Jack I was away for a few days.....As far as I know the loader valve has a power beyond port straight from the factory and I can't think of any "kit" he may be talking about. The only thing I think he may be reffering to is a seperate valve you can mount in the vicinity of the loader valve which taps off of the power beyond port on the loader valve. This is what you would use to run the power angle on the plow. With this set up you can tilt the blade fwd and back with the curl/dump circuit as well as angle your blade with the add on valve. You would have an extra valve and control seperate from the loader controls. This usually comes with the front blade kit if it is specified when ordering. However this will add to the price of the blade kit (not sure how much $$). I do know the price of the 4 pos valve is about 40 bucks higher than the 3 pos valve which will obviously save you money in the long run. I personally can't think of many advantages to having the ability to tilt your plow blade, but if you can, then this may justify the additional cost of the add on valve. Just a ballpark geuss, with the additional valve added on later you may be looking at 200 to 300 bucks more. Now keep in mind, this is the front blade kit that mounts to your loader assy. Most of the ones I have installed were supplied by Curtiss.
   / LA482 loader valve #13
have a L482 loader that only goes up in a very short space on the valve ,if you push the lever down farther the lifting stops,the valve has no play and works fine in every other position
   / LA482 loader valve #14
Bob, you need to start a new thread "Help needed on L482 loader".
ron
   / LA482 loader valve #15
I have an LA482 Loader on my 2002 Kubota L3010 with only 260 hours:. The valve has a problem lifting the loader. All positions work fine except trying to lift. It is very touchy to position the handle so the bucket lifts. If I push down , it has to be very slow and then the bucket will lift. If I push farther, the bucket stops and won't go up any further even though the lever still has room to be pushed farther down. Lowering , curling and emptying all work fine. Any suggestions would be greatly appreciated.
John Deere 6230 Premium with Trebro Sod Harvester (A52128)
John Deere 6230...
2012 CHEVROLET SILVERADO 2500HD (A50854)
2012 CHEVROLET...
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2020 KUBOTA RTV...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
