LA482 loader valve
/ LA482 loader valve #1
jack9166
North Jackson Ohio
Kubota L4060
Hi, I just put money down on a new Kubota LA482 loader and am getting it installed next week.
My question is about the valve.........at some point I might put a front power angle blade on and I asked the dealer if I needed the 4 way vlave and he said no! he said that if I put the power angle valve on I need to get a power beyound kit.
Does anybody know about these?
Thanks
Jack
/ LA482 loader valve #2
I think your dealer may be a little confused. Check this <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=buykubota&Number=101191&page=&view=&sb=&o=&vc=1/>post</A> before you decide on the valve.
Thanks for your quick reply. So what does a power beyond kit do?
/ LA482 loader valve #4
A power beyond kit will allow you to tap into the 3ph hyd's and is generally used for installing another hyd valve to operate other implements from the back, hyd power rake, top and tilt, etc. it makes for a neater assembly rather than runing hoses back from the power beyond of the loader valve. Wich you can still do. The loader valve will have a power beyond port.
Could'nt I run the angle blade from the power beyond on the loader valve.
I would rather have the 4 postion valve but the dealer said he can't get one.
/ LA482 loader valve #6
Yes, you can run off of the loader valve power beyond. It's just the additional cost and bulkiness of the additional valve. When the 4-position does all that for you. Surely someone out there has a 4-position valve he can get his hands on. The valve usually comes with the loader, so maybe that's all he has in stock. Dealers usually prefer to sell off stock, rather than order new. Call around to other dealers to get a feel for weather or not there is a shortage from Kubota. Maybe Carvers can help. I just think you would be happier with the 4-pos valve.
Kubmech.......Thanks for your help! Right now there is a shortage on the LA482 loader and all the dealers a saying it will be December before they can get one. I did find one dealer about 30 miles away that gave me a great price and will even pick up my tractor and return after installation for an extra 50.00 but the loader he has in stock only has the 3 postion valve. I wonder if they could swap out the 3 for the 4 postion with Kubota?
/ LA482 loader valve #8
I geuss all I can add is see how hard the dealer will work for you on this. Maybe they are short on loader assy's but can get just the valve through whole goods. It may end up costing them more which of course may end up costing you more. That would most likely be the deciding factor. Of course, waiting till December may be an option.
If they can't get the 4 way valve now I may end up waiting until December.
Do you know if extra hydraulic hook ups come with the 4 way valve?
Thanks
Jack
/ LA482 loader valve #10
If you mean extra quick couplers? No, you would have to buy them seperately. If you are installing a loader mounted front blade with power angle you would need two additional female coupler ends. They would attach to the ends of the power angle cylinder hoses and couple in to the bucket curl/dump side of the loader valve. A chain and hook assy would then be installed on the loader frame front crossbar to maintain the blade vertically.
Kubmech, Thanks for all your help..........the dealer told me there is a power beyond kit that goes on the loader valve, does he know what he is talking about?
Thanks
Jack
/ LA482 loader valve #12
Sorry Jack I was away for a few days.....As far as I know the loader valve has a power beyond port straight from the factory and I can't think of any "kit" he may be talking about. The only thing I think he may be reffering to is a seperate valve you can mount in the vicinity of the loader valve which taps off of the power beyond port on the loader valve. This is what you would use to run the power angle on the plow. With this set up you can tilt the blade fwd and back with the curl/dump circuit as well as angle your blade with the add on valve. You would have an extra valve and control seperate from the loader controls. This usually comes with the front blade kit if it is specified when ordering. However this will add to the price of the blade kit (not sure how much $$). I do know the price of the 4 pos valve is about 40 bucks higher than the 3 pos valve which will obviously save you money in the long run. I personally can't think of many advantages to having the ability to tilt your plow blade, but if you can, then this may justify the additional cost of the add on valve. Just a ballpark geuss, with the additional valve added on later you may be looking at 200 to 300 bucks more. Now keep in mind, this is the front blade kit that mounts to your loader assy. Most of the ones I have installed were supplied by Curtiss.
/ LA482 loader valve #13
have a L482 loader that only goes up in a very short space on the valve ,if you push the lever down farther the lifting stops,the valve has no play and works fine in every other position
/ LA482 loader valve #14
Bob, you need to start a new thread "Help needed on L482 loader".
ron
/ LA482 loader valve #15
I have an LA482 Loader on my 2002 Kubota L3010 with only 260 hours:. The valve has a problem lifting the loader. All positions work fine except trying to lift. It is very touchy to position the handle so the bucket lifts. If I push down , it has to be very slow and then the bucket will lift. If I push farther, the bucket stops and won't go up any further even though the lever still has room to be pushed farther down. Lowering , curling and emptying all work fine. Any suggestions would be greatly appreciated.
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A64553)
2025 BS43 44in...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
Club Car Carryall 2 Electric Utility Cart (A64553)
Club Car Carryall...
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
1991 FRUEHAUF 45'X96" FLATBED TRAILER (A65643)
1991 FRUEHAUF...
