LA463 curl cylinders weeping
   / LA463 curl cylinders weeping #1
TDVT
NEK Vermont
'49 Ford 8N & '08 Kubota L3400
Now that it's tractor weather again here in Northern Vermont (other than moving snow) I've been out trying to get a head-start on things with our spectacular warm & early spring.
Today while working on a brush fork attachment, I noticed the bucket-ends of the loader arms were sprayed with oil & then noticed that the curl cylinders (at the seal) were also oily. Not dripping, but you could get a drop on the end of your finger from the weep hole. The lift cylinders, which look to me as though they are the same, are dry.
I DID do a bit of digging week before last but I don't abuse the tractor (83 hrs w/regular maintenance). Is this a normal occurrence?
We split tractor time between the 3400 & our old Ford (hence low hours) but this is the first loader I've had & the warranty is over at the end of this month.
Thanks, TD
   / LA463 curl cylinders weeping #2
One of mine did the same thing when it was new. Got it fixed but it wasn't even almost worth the trouble (another story). I think it's got a lot to do with relieving the pressure on the loader valve after shutting down, I mean working it like you would before removing the loader. For mine anyway, I think most of the leaking occurs while the tractor is trying to relax after a hard days work.
Always avoid putting your finger on leaking hydraulics under pressure!
Thanks for your reply.
Certainly a readily-replaceable part if there were an issue, I just didn't know if it was an early warning sign or not. Seems odd both sides would weep if it were a real issue.
Mods- Please feel free to move this, thought I was in the owning/operating forum when I posted, SORRY!
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2003 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2003 CATERPILLAR...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
