LA463 curl cylinders weeping
   / LA463 curl cylinders weeping #1
TDVT
NEK Vermont
'49 Ford 8N & '08 Kubota L3400
Now that it's tractor weather again here in Northern Vermont (other than moving snow) I've been out trying to get a head-start on things with our spectacular warm & early spring.
Today while working on a brush fork attachment, I noticed the bucket-ends of the loader arms were sprayed with oil & then noticed that the curl cylinders (at the seal) were also oily. Not dripping, but you could get a drop on the end of your finger from the weep hole. The lift cylinders, which look to me as though they are the same, are dry.
I DID do a bit of digging week before last but I don't abuse the tractor (83 hrs w/regular maintenance). Is this a normal occurrence?
We split tractor time between the 3400 & our old Ford (hence low hours) but this is the first loader I've had & the warranty is over at the end of this month.
Thanks, TD
   / LA463 curl cylinders weeping #2
One of mine did the same thing when it was new. Got it fixed but it wasn't even almost worth the trouble (another story). I think it's got a lot to do with relieving the pressure on the loader valve after shutting down, I mean working it like you would before removing the loader. For mine anyway, I think most of the leaking occurs while the tractor is trying to relax after a hard days work.
Always avoid putting your finger on leaking hydraulics under pressure!
Thanks for your reply.
Certainly a readily-replaceable part if there were an issue, I just didn't know if it was an early warning sign or not. Seems odd both sides would weep if it were a real issue.
Mods- Please feel free to move this, thought I was in the owning/operating forum when I posted, SORRY!
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
TEST BID LOT (A50775)
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
