Loader LA402 Float ?
/ LA402 Float ? #1
Ovaleye
Iowa
Kubota B2910
Dose the LA402 loader have a float position?
If it dose how do you put it in float?
Thanks
/ LA402 Float ? #2
I don't know that specific loader but most of them do. To engage float you push the control lever all the way forward. There is normally a detent that you push past.
MarkV
/ LA402 Float ? #3
Thanks
i have a kubota b7800 with la402 loader. it has float. to use float, simply push the control lever straight up/forward to its second position and it will click/pop into the float position. it will stay there until you pull it back, you don't have to hold it there.
/ LA402 Float ? #4
I was going to answer, but you've got 2 good answers already, and both right of course.;)
/ LA402 Float ? #5
Same here but want to add something. At times my valve won't go into float, it is a brand new loader maybe 100 hrs. Works most of the time and then sometimes it won't. I have not isolated the problem but am wondering if anyone else has noticed this.
/ LA402 Float ? #6
I don't think I ever had that problem, although it seemed to require a little harder push sometimes than at other times, but I wouldn't swear that wasn't my imagination.
/ LA402 Float ? #7
That is one of the symptoms I experienced to the point it would not go in, just seemed to want to raise the front end. I use float more so in the winter though?.....
/ LA402 Float ? #8
Might be rust, dirt, or broken spring in the float system. That is under the little cap at the end of the spool. It well be longer, most of time, then the other spool because it only has the spring center system. I would look at the parts brake down 1st, there is some balls in it.
/ LA402 Float ? #9
Had same problem when mine was new, dealer came out and fixed it. I wasn't here so I don't know what they did, but they replaced something in the loader valve.
/ LA402 Float ? #10
I had my Float stop working on my LA402 and just needed to get the new bearings and spring. Got some advice from JJ and that helped. the parts are pricey but I got it back up working just fine. It's not hard, though I recommend taking the valve controller off as the spool with the parts you need to replace are on the bottom of the controller.
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Adams Under Truck Conveyor (A63688)
Adams Under Truck...
JOHN DEERE 1700 - 6R VACUUM PLANTER (A63291)
JOHN DEERE 1700 -...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
