LA304 Quick Attach
/ LA304 Quick Attach #1
KB2320
Just took delivery of my B2320 today. I wanted forks for the loader and had tried a set of bucket forks but didn't like them at all. My dealer decided to try an experiment:
He ordered the LA504 forks and guess what - they fit. He then ordered the LA504 QA and of course that fit perectly as well.
He called Kubota at the outset and they told him it could not be done. :)
/ LA304 Quick Attach #2
Yes, it all does fit. There are a few of us with the QA on our B2x20's, and we all like them. There have been a few threads that you may want to look up. Some folks are using the larger materials bucket too, and so far that seems to be working as well.
/ LA304 Quick Attach #3
I think Kubota may be saying that (they don't fit) because of course there may be some people who will try to pick up to much weight with the forks and tip the tractor. Loaded tires, counterweight and common sense like the way ChuckinNH was moving his big rock (go slow) in one of the threads is the way to go.
/ LA304 Quick Attach #4
I'm sure that bstrom is right about both Kubota, and some dealer's thinking. The larger B3200 is both longer, and the rear tires hold much more fluid for weight. If you put the tips of the tines under something immovable on a B2x20 series with no additional ballast besides the loaded tires, you can lift the rear of the tractor pretty easily. Of course, like many other things, if you use your head, and think a bit, you can also easily stay out of trouble. I use the ground to support the rear of the tines while I curl often for example. The tines can be pushed entirely,(or nearly so) under a rock, or stump before you start your curl, and that allows you to get that weight back where it belongs before you even try lifting. Once that weight is back against the upright support, you can safely carry more than you could with something strapped / chained to the front of a loader bucket. I find that much nicer for odd shaped loads like stumps, or rocks. The other thing I have found is that the longer tines ( longer than the depth of the bucket) make it much easier to place an odd shaped load where you want it, I. E. placing rocks on a pile, or wall. You can place the tines where you want the load to go while keeping the weight back against the upright, and then gradually raise, and curl forward until the weight slides down the tines to where you want it......... supported, and in view all the while. Not only is the load supported, the tractor is too, and that is really nice if you aren't on ground that is level. I almost think that the forks would be a better tool for working on rock walls than a backhoe with thumb. The forks make a good workbench, and the tips of the tines allow you to turn rocks before lifting them in place. Of course you can do that easily with a thumb too, but it scrapes up the rock more, and you have very limited reach in comparison so you can go get a rock, or two with the tines from further away without repositioning, picking up the stabilizers, etc.
OK, I like my forks :D :D
/ LA304 Quick Attach #5
Thanks Chuck that's great information. Now I really want to get the forks soon especially with all the rock work around here. I've got a big pile of rocks from a small excavator with a thumb and my poor back can't take much more of pushing them in the bucket to take them places.:(
/ LA304 Quick Attach #6
Chuck Do you know if your bucket is the same as the LA 352,, I have a B series 7610 and would love to have the kubota QA for it,,
/ LA304 Quick Attach #7
I'm afraid that the loader was changed between your tractor, and mine. The loader arms are much closer together, and so the buckets are different. On the other hand, your loader may be the same dimensions as the one used on the B7800/B2710/B2910 as far as pin up goes, and there was / is a QA available for those loaders too that is/was the same style as mine, and accepted the Kubota forks, and different bucket sizes designed for those tractors............. worth a look. My guess is that it would work.
/ LA304 Quick Attach #8
Hi All:
We recently acquired a B2420 with a dozer blade and a bad clutch. Can some one post some detail photos of the front end loader LA 304, please.
If anyone would like a video documentary of the clutch replacement procedure ,let me know and I will Utube one for you.
thanks
Rayonger
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2013 PETERBILT 365(INOPERABLE) (A65643)
2013 PETERBILT...
1983 Mack DM492S Cab & Chassis (A62679)
1983 Mack DM492S...
(16) Kinze 3000 Insecticide Boxes (A65640)
(16) Kinze 3000...
NEW Landhonor LHR-AIW1  1" Air Impact Wrench  (A62679)
NEW Landhonor...
3 Point Trailer Mover (A65640)
3 Point Trailer...
