Loader LA243 Hookup P.I.T.A - middle hoses will NOT connect
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect
RESOLVED!! I didn't think it would have been the FEL but that was where the pressure was built up. I took a short piece of wooden doll rod, inserted into the female fitting, covered with one of the 200 blue surgery towels I have stockpiled (wife is a surgical nurse and those towels are AWESOME), gave it a couple whacks and resolved! They slid on like I would expect (wish I could have my skin back).
Put on the forks, moved 2 piles of brush and the thunderstorms rolled in.....
Just wasn't meant to be today but learned a great tip regarding the FEL and making sure I disconnect properly.
Thanks everyone!!!!!!!!!!!!!!!!!
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #12
If your FEL is exposed to hot sun, pressure does expand.
Still, the best thing, and I have had to re-start the tractor and do it, if I forget, is to do the rotation of joystick thing. I find it takes 3 or 4 good rotations to release the pressure.
I don't particularly find the location on the BX valves very accessible, but on the other hand, I like that they are protected better than just hanging out somewhere, as I have seen on other tractors.
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #13
Good to hear :thumbsup: these things are really easy to remove/install. I usually back up enough to clear the FEL so the valves are easy to access.
Have you watched the video from Messick's? It's on You Tube.
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #14
RESOLVED!!
I'd like to know how often you change the prop on that boat driving it around the pasture.
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
