Loader LA243 Hookup P.I.T.A - middle hoses will NOT connect
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect
RESOLVED!! I didn't think it would have been the FEL but that was where the pressure was built up. I took a short piece of wooden doll rod, inserted into the female fitting, covered with one of the 200 blue surgery towels I have stockpiled (wife is a surgical nurse and those towels are AWESOME), gave it a couple whacks and resolved! They slid on like I would expect (wish I could have my skin back).
Put on the forks, moved 2 piles of brush and the thunderstorms rolled in.....
Just wasn't meant to be today but learned a great tip regarding the FEL and making sure I disconnect properly.
Thanks everyone!!!!!!!!!!!!!!!!!
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #12
If your FEL is exposed to hot sun, pressure does expand.
Still, the best thing, and I have had to re-start the tractor and do it, if I forget, is to do the rotation of joystick thing. I find it takes 3 or 4 good rotations to release the pressure.
I don't particularly find the location on the BX valves very accessible, but on the other hand, I like that they are protected better than just hanging out somewhere, as I have seen on other tractors.
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #13
Good to hear :thumbsup: these things are really easy to remove/install. I usually back up enough to clear the FEL so the valves are easy to access.
Have you watched the video from Messick's? It's on You Tube.
   / LA243 Hookup P.I.T.A - middle hoses will NOT connect #14
RESOLVED!!
I'd like to know how often you change the prop on that boat driving it around the pasture.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
ALLISON TRANSMISSION (A55745)
ALLISON...
Blue Diamond 103709 (A53317)
Blue Diamond...
Mobile Transformer and Power Substation Portable Power Supply (A55302)
Mobile Transformer...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A55315)
2017 Cadillac...
