Sep 7, 2017 / L6060 Sway Links #21 L Leejohn Elite Member Joined Sep 16, 2007 Messages 4,073 Location Doniphan, Mo. Tractor Kubota L4240, B7800 & BX2660 If the mounting pin holes are big enough on the mower and if there is room. You might could just get cat 2 pins and do away with that long mower pin.
Sep 8, 2017 / L6060 Sway Links Thread Starter #22 OP S SDT Veteran Member Joined May 13, 2005 Messages 1,845 Location SE Indiana Tractor Multiple Fords and Kubotas JWR said: SDT: How about a photo of where you put the washers ? Tks. Click to expand... Sorry, no photos, JWR. The washers are outside of the lift arm between the arm and the mower outside vertical structure through which the pins pass. SDT
