L6060 rear glass struts disassembly?
   / L6060 rear glass struts disassembly? #1
jk96
Missouri
Kubota L6060
How do these come apart? Replacing the rear glass and need to disconnect the strurs feom the glass brackets so I can install them into the glass without having to try and keep the entire assembly compressed while doing so.
   / L6060 rear glass struts disassembly? #2
The ball joint (Item #240) threads out of the bracket.
Thank you all.
   / L6060 rear glass struts disassembly? #6
Beat me to it. Follow the video.. They are all like this.
   / L6060 rear glass struts disassembly? #7
I should have put a little more thought into my response.
   / L6060 rear glass struts disassembly? #8
Hang on to the clip, they like to go flying if pried too far back.
   / L6060 rear glass struts disassembly? #9
Do NOT attempt to keep them Compressed. Open the glass Fully then disassemble per instructions below.
   / L6060 rear glass struts disassembly? #10
Those little spring clips slide off - then the cylinder pops off the ball stud(s). If you stop into an auto supply store (or similar) they may have a package you can open to read the R&R instructions. Also, look for a YouTube on Removing Gas Operated Struts
"To remove a gas-operated strut, you'll typically need to release the mounting clips or fasteners at both ends of the strut, then carefully detach it from the mounting points. This often involves using a flathead screwdriver or a tool to release the clip and then pulling the strut away from the ball joint or mounting bracket. "
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
90018 (A48082)
90018 (A48082)
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2007 IH 4300 Dump Truck (A47384)
2007 IH 4300 Dump...
KOOMEY INC VALVE ACTUATOR (A52472)
KOOMEY INC VALVE...
