L6060 rear glass struts disassembly?
   / L6060 rear glass struts disassembly? #1
jk96
Missouri
Kubota L6060
How do these come apart? Replacing the rear glass and need to disconnect the strurs feom the glass brackets so I can install them into the glass without having to try and keep the entire assembly compressed while doing so.
   / L6060 rear glass struts disassembly? #2
The ball joint (Item #240) threads out of the bracket.
Thank you all.
   / L6060 rear glass struts disassembly? #6
Beat me to it. Follow the video.. They are all like this.
   / L6060 rear glass struts disassembly? #7
I should have put a little more thought into my response.
   / L6060 rear glass struts disassembly? #8
Hang on to the clip, they like to go flying if pried too far back.
   / L6060 rear glass struts disassembly? #9
Do NOT attempt to keep them Compressed. Open the glass Fully then disassemble per instructions below.
   / L6060 rear glass struts disassembly? #10
Those little spring clips slide off - then the cylinder pops off the ball stud(s). If you stop into an auto supply store (or similar) they may have a package you can open to read the R&R instructions. Also, look for a YouTube on Removing Gas Operated Struts
"To remove a gas-operated strut, you'll typically need to release the mounting clips or fasteners at both ends of the strut, then carefully detach it from the mounting points. This often involves using a flathead screwdriver or a tool to release the clip and then pulling the strut away from the ball joint or mounting bracket. "
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
