L5740 air conditioner drains clogged.
   / L5740 air conditioner drains clogged. #12
I believe vinegar will react with the aluminum alloy heat exchangers. Not a chemist but I believe it will.
   / L5740 air conditioner drains clogged. #13
Our fridge occasionally gets that drain clogging problem.
My cure is to poke a semi ridged wire to clear the clog.
I found that RG58 Coax was just about right for that chore.
   / L5740 air conditioner drains clogged. #14
John Deere uses some type of corrugated tube for the condensate drains. The run down inside the front cab columns. You can pull a rubber plug out of the bottom & you will find the tube has an S bend in it at the bottom like a sink drain. Pull the tube out & you can run a wire up it to clear the blockage. Wasps & dirt dobbers like to build nests in the tube around here so it is a regular maintenence item.
Wire will not go around the bends unless you straighten the tube.
Kubota used Nut Certs in the roof that the screws screw into and on mine, the nut certs cracked the plastic roof where Kubota installed them and I wasn't about to buy a new roof ($1000.00) for a new roof, so I fiber glassed the nut certs in and the cracks they made in the roof. Worked excellent.
You might want to order a new roof gasket, I did. My roof gasket has been deteriorating right along, so I replaced it this spring. My M is a 2004 model btw.
Pictures are before I replaced the gasket. It's just under 100 bucks at the dealer and cone with adhesive on it, pull the backer tape and stick it.
Great info, 5030. Thanks!
   / L5740 air conditioner drains clogged. #16
The Kubota roof ac drains run down the front left and right cab frames (which are also the cab ROPS frame as well), straight from the condensate tray the ac and heater cores are in to the ground. They exit at the rear of the engine on the right and left side, straight shot from the tray.
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
2007 Ford Ranger Ext. Cab Pickup Truck (A56858)
2007 Ford Ranger...
John Deere 4510 (A53317)
John Deere 4510...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
