L5740 air conditioner drains clogged.
   / L5740 air conditioner drains clogged. #12
I believe vinegar will react with the aluminum alloy heat exchangers. Not a chemist but I believe it will.
   / L5740 air conditioner drains clogged. #13
Our fridge occasionally gets that drain clogging problem.
My cure is to poke a semi ridged wire to clear the clog.
I found that RG58 Coax was just about right for that chore.
   / L5740 air conditioner drains clogged. #14
John Deere uses some type of corrugated tube for the condensate drains. The run down inside the front cab columns. You can pull a rubber plug out of the bottom & you will find the tube has an S bend in it at the bottom like a sink drain. Pull the tube out & you can run a wire up it to clear the blockage. Wasps & dirt dobbers like to build nests in the tube around here so it is a regular maintenence item.
Wire will not go around the bends unless you straighten the tube.
Kubota used Nut Certs in the roof that the screws screw into and on mine, the nut certs cracked the plastic roof where Kubota installed them and I wasn't about to buy a new roof ($1000.00) for a new roof, so I fiber glassed the nut certs in and the cracks they made in the roof. Worked excellent.
You might want to order a new roof gasket, I did. My roof gasket has been deteriorating right along, so I replaced it this spring. My M is a 2004 model btw.
Pictures are before I replaced the gasket. It's just under 100 bucks at the dealer and cone with adhesive on it, pull the backer tape and stick it.
Great info, 5030. Thanks!
   / L5740 air conditioner drains clogged. #16
The Kubota roof ac drains run down the front left and right cab frames (which are also the cab ROPS frame as well), straight from the condensate tray the ac and heater cores are in to the ground. They exit at the rear of the engine on the right and left side, straight shot from the tray.
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2014 MACK CZU613 MID-ROOF SLEEPER (A50854)
2014 MACK CZU613...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
