L5740 3rd remote
   / L5740 3rd remote #1
firec
Bronze Member
Upstate NY
Kubota L5740 / L3830 / BX2200
I have a L5740 with the 3rd remote that works fine with my grapple bucket but with the front mount snowblower, I set it to the chute valve and it will not work correctly. When I purchased the unit when you activated the remote the shoot shot up or down with no feather control? I purchased reducer valves which sort of helped but never gave good control. this year the cylinder will go one way and can only be assisted to go the other. I removed the valves and it acts the same way. The 3rd remote is electric, does anybody have any ideas on why this will not work but the grapple will? I tested the cylinder on another tractor and it worked fine.
   / L5740 3rd remote #2
Have you tried it with one of the other two remotes?
   / L5740 3rd remote #3
If the 3rd electric ports are tied to the curl/dump side of your loader control it will not work on a small hydraulic cylinder... the curl/dump circuit on your loader is regenerative and feeds the same thing to Both ports in the dump cycle... it works with a larger cylinder because of the shaft size reduces the piston surface area... KennyV
   / L5740 3rd remote
Thanks for the responses. KennyV, I'm not sure if I understand your response. I have the Kubota third remote so I'm not sure how it is tied in. Yesterday, I removed the reducing valves that I got from the dealer last year and tried a plug that was put in the line and drilled out with a small bit thinking after it equalized the pressure it should work but the cylinder only goes one way which makes no sense to me? After I get done clearing the foot of snow we got last night I will try connecting it to another remote and see what it does.
Thanks again.
   / L5740 3rd remote #5
If you are controlling a cyl with a remote valve and the cyl is a DA cyl, and your valve does not have regen, then you should be able to operate the cyl. If not, then I would suggest one of the QD's in not connected correctly.
Even if the valve has regen, just go past the regen soft stop and the cyl should operate.
   / L5740 3rd remote
can you please explain what you mean by DA and QD?
   / L5740 3rd remote
Thanks, it's a Monday... I picked up a larger cyl to try.
   / L5740 3rd remote
The larger cyl works fine, now to change the mounting bracket. Thanks for the answers.
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
294 (A52706)
294 (A52706)
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
