Oil & Fuel L5240 - Engine Oil Drain - Both sides of sump?
   / L5240 - Engine Oil Drain - Both sides of sump? #1
bitseeker
Mount Shasta, California
GL5240
The L5240 has a deep channel for the PTO shaft, running fore and aft, through the engine oil sump forming what seems to be two sumps. There are drain bolts on each side. It appears that the drain bolt on each side must be removed and each side drained.
Because of the snow blower mount below the sump(s), and the need to make up an oil diverter, only one drain bolt at a time may be removed.
Do both bolts need to be removed?
Thanks.
   / L5240 - Engine Oil Drain - Both sides of sump? #2
if you don't, you will leave almost 2 quarts behind. Not ideal, but also not a total disaster, assuming you do regular oil changes. KennyV
   / L5240 - Engine Oil Drain - Both sides of sump? #3
Yep.
DevilDog
   / L5240 - Engine Oil Drain - Both sides of sump? #4
One at a time is fine. Do both. Don't leave old oil in one side.....
The shaft dividing the oil pan is the front axle drive shaft. PTO shaft exits the rear of the tractor.
2017 Nissan Rogue SUV (A50324)
2017 Nissan Rogue...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2013 Ford F-450 Altec AT200A 36FT Bucket Truck (A50323)
2013 Ford F-450...
John Deere 637 Disk (A50514)
John Deere 637...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
