Oil & Fuel L5240 - Engine Oil Drain - Both sides of sump?
   / L5240 - Engine Oil Drain - Both sides of sump? #1
bitseeker
Mount Shasta, California
GL5240
The L5240 has a deep channel for the PTO shaft, running fore and aft, through the engine oil sump forming what seems to be two sumps. There are drain bolts on each side. It appears that the drain bolt on each side must be removed and each side drained.
Because of the snow blower mount below the sump(s), and the need to make up an oil diverter, only one drain bolt at a time may be removed.
Do both bolts need to be removed?
Thanks.
   / L5240 - Engine Oil Drain - Both sides of sump? #2
if you don't, you will leave almost 2 quarts behind. Not ideal, but also not a total disaster, assuming you do regular oil changes. KennyV
   / L5240 - Engine Oil Drain - Both sides of sump? #3
Yep.
DevilDog
   / L5240 - Engine Oil Drain - Both sides of sump? #4
One at a time is fine. Do both. Don't leave old oil in one side.....
The shaft dividing the oil pan is the front axle drive shaft. PTO shaft exits the rear of the tractor.
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
Mahindra 26XL Tractor 4X4 Loader Backhoe (A51243)
Mahindra 26XL...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2020 Kinze 3505 High Speed 6/11 Planter (A51039)
2020 Kinze 3505...
WEATHERFORD MP-10 TRIPLEX MUD PUMP POWERED BY A CATERPILLAR 3412 ENGINE (A50854)
WEATHERFORD MP-10...
