L5030 vs new M or TN
   / L5030 vs new M or TN
Thank you all for the advice. This helps a lot. I was thinking the bigger I get the happier I will be in the long run. I also need to dig a low water crossing across a creek. Is it possible to backhoe with a cab or should I just hire it done. Got a quote last night from an excavator who would do it for $1500 plus permits. The problem is the only way in is over my 1 yr old blacktop and I'm afraid the 40 ton excavator will really tear it up.
John
   / L5030 vs new M or TN #12
Not if the operator/contractor has road pads on the tracks and lays down the proper mats. $1500.00 is a lot cheaper than a 3 point/subframe backhoe and yes, Bradco makes a backhoe that will fit cab models of Kubota. The OEM don't.
   / L5030 vs new M or TN #13
John
I run over blacktop all the time wiht my 44,000 # excavator. If I go straight and don't turn , no problem. If you're worried, lay down a few sheets of plywood or some old tires for it to drive on.
Andy
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
Skid Pro Quick Attach Plow (A50514)
Skid Pro Quick...
Truck Bed (A50774)
Truck Bed (A50774)
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
John Deere 843 Corn Head (A50514)
John Deere 843...
