L5030 vs new M or TN
   / L5030 vs new M or TN
Thank you all for the advice. This helps a lot. I was thinking the bigger I get the happier I will be in the long run. I also need to dig a low water crossing across a creek. Is it possible to backhoe with a cab or should I just hire it done. Got a quote last night from an excavator who would do it for $1500 plus permits. The problem is the only way in is over my 1 yr old blacktop and I'm afraid the 40 ton excavator will really tear it up.
John
   / L5030 vs new M or TN #12
Not if the operator/contractor has road pads on the tracks and lays down the proper mats. $1500.00 is a lot cheaper than a 3 point/subframe backhoe and yes, Bradco makes a backhoe that will fit cab models of Kubota. The OEM don't.
   / L5030 vs new M or TN #13
John
I run over blacktop all the time wiht my 44,000 # excavator. If I go straight and don't turn , no problem. If you're worried, lay down a few sheets of plywood or some old tires for it to drive on.
Andy
Toro Workman Cart (A50322)
Toro Workman Cart...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2007 TRANSCRAFT 40X96 FLATBED (A50854)
2007 TRANSCRAFT...
2025 FREIGHTLINER M2 NON CDL BOX TRUCK (A51222)
2025 FREIGHTLINER...
