L5030 no power
/ L5030 no power #1
maxton
I need some help! I was mowing Saturday when I shut off the engine I heard a click. I went to restart the tractor and all that happened was the start relay buzzed. I checked the fuses underpass and by the battery and none were blown. The relays checked out fine as did the ignorant switch. I have no power anywhere but at the starter. Nothing else. Also there is no power going to the 30amp starter fuse in the cab fuse box, any help would be greatly appreciated!
/ L5030 no power #2
Battery connector? Ground cable?
/ L5030 no power
Thanks for replying, it's all good
/ L5030 no power
I checked battery voltage used an volt meter from battery positive you chassis. All seems good,
/ L5030 no power
OK here we go! Battery voltage is 12.9 at the posts, rechecked put under load meter went to 0! New battery,all is well! Goes to show you check the simple things first!
/ L5030 no power #6
Glad you found it. I had the cable connection to battery terminal go bad. Would show voltage, but didnt handle current flow.
2002 John Deere 737 Zero Turn (A63116)
2002 John Deere...
Swict 66" Bucket (A62183)
Swict 66" Bucket...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
Survey Kit (A62183)
Survey Kit (A62183)
TONUTTI 8 WHEEL V-RAKE (A63290)
TONUTTI 8 WHEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
