L5030 HST forward most Drain
   / L5030 HST forward most Drain #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
I'm changing the hydraulic fluid (UDT) on my L5030 and noticed on the front drain requires a large alan wrench (The manual shows a regular drain plug but that is not what is there.)
Does anyone know what size alan wrench is required.
Thanks
   / L5030 HST forward most Drain #2
I can look in the shop manual, but I often find that the head of a hex bolt can be found to fit...then, use a wrench on a pair of nuts jammed together, or a t-handle welded on ...of, you can mike the one that fits to find the size--easier than taking an inside measurement, IMHO
Good idea JoeL!
I called the Kubota dealership and spoke with a mechanic and he said that there are just 3 drains for the HST. So I went ahead and drained the three and filled up with UDT fluid and it was suppose to take 11.9 gallons but only 10.5 fit. Now I really don't know if the alan type bolt was a drain or not and if there are really 4 drains like the manual says ???:confused:
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
2018 Vermeer D23X30 S3 Navigator Directional Drilling Machine (A49461)
2018 Vermeer...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2020 J&M 1151-22T Classic Grain Storm Grain Cart (A50657)
2020 J&M 1151-22T...
