L5030 battery change out
   / L5030 battery change out #1
txdon
Super Star Member
Central Texas
Kubota M6H-101
My battery is slowly wearing out. I looked under the hood and I see that the air cleaner has to be removed and the breaker bracket needs to be bent out of the way and then it might just have enough clearance past the rear of the headlight to be able to remove the battery by pulling it straight up, maybe.
Or is there an easier way?
Thanks!
   / L5030 battery change out #2
txdon,
It might not be the same, but on my L3130 the headlight/grill comes out with two wing nuts to gain access to the battery. Maybe yours is the same.
   / L5030 battery change out #3
Here is a picture to show what I was talking about in the previous thread.
I saw that wing nut! I'll check that out thanks.
Does anyone have a preference on a good maintenance free tractor battery? The Dealer did not have any OME batteries.
   / L5030 battery change out #5
I forgot to mention, but the bottom of the headlight/grill assembly has pins that are in rubber grommets. Tilting the assembly forward and rocking a bit helps get it out depending on how tight yours is. Also do not forget to disconnect the headlight wiring harness if there is not enough slack in the wiring.
   / L5030 battery change out #6
As stated, the headlight assembly easily comes out by unplugging and the wing nut. I usually but Die Hard or Interstate batteries, but have not replaced the one in my L5030, so I don't know the model numbers. Good luck.
   / L5030 battery change out #7
Buy one from Costco. Change it out before the warranty ends and you'll have a lifetime supply of batteries for the price of the first one.
Just measure the L x W x H and where the terminals are and you are good to go.
   / L5030 battery change out #8
Because of location some people are getting AGM or spairal wound Optimal batteries so any leakage will not harm the radiator.
David Kb7uns
   / L5030 battery change out #9
When you buy a battery you are buying lead...
There are a lot of ways to make one lead acid battery "sound" better than the next...
Get the heaviest battery (that fits the space you have available) for the $ you can find. Should last many years and you will save $$ KennyV
It is not the easiest battery to get to and as David pointed out it is next to the radiator so the battery must be a sealed, maintenance-free battery as the one from the factory. One dealer said the original batteries were made in Japan and they do not cary them. Why not? That was a good battery lasting an incredible 8 years in this heat.
71050 (A49346)
71050 (A49346)
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
TRUCKING INFO (A50775)
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
