l4610 remove fel control valve
   / l4610 remove fel control valve
oh, im sorry, yes, it did show signs of having been tampered with before, but everything seems to be in order as far as I can tell
   / l4610 remove fel control valve #12
Maybe a long shot, but is it possible the 2 valve spools became interchanged at some point in the valve's history?
The symptom you describe of slow motion when it moves brought to mind a design feature of some Kubota loader valves. To control how fast the load dumps when extending the curl cylinders, full pressure is applied to both sides of the piston. The rod side has less area so the big side wins and the cylinder moves, but much slower than it would with free exhaust on the rod side. Then I got thinking if your spools were swapped the boom would raise slowly. Would maybe have some other strange behavior too. Ok I admit it's a very long shot.
I was looking at the valve .pdf and it appears it could be assembled in any order - but the spool groove spacing is not the same on both.
I wondered about that, but the float function on the lift spool does work. It doesn't lock in place well, but it does float. That leads me to believe the spools are not swapped.
   / l4610 remove fel control valve #14
In the diagram it looks like the detent feature is an add-on that screws into the end of the spool - the actual float performance may just be a wide passage in the body that connects the work ports - either spool would float in that bore ?
Yeah, but I assumed that the float feature had to be on the spool for the detent to work. Maybe not. I'll test the theory anyway. I think if I just flip flop the lines from one set of work ports to the other it should prove or disprove the swapped spools without any disassembly. See any issue with that?
   / l4610 remove fel control valve #16
Nope - its a good idea. I'm not real confident the spools can even be swapped. Their fit in the bore is very precise and they may not be interchangeable.
I really think they could be interchangeable. I hope that is the issue. But I doubt it. Gotta try before spending $$$ on a valve tho
   / l4610 remove fel control valve #18
The clearance is very small - sometimes as little as .0002" on the diameter (up to .0012" +/-). They get it by reaming/honing the bores in the body and then grinding the spool lands to fit.
Pretty sure the spool mentioned in your other thread that was out .003" was damaged beyond repair. The annular leakage has to be very small. In the hydraulic valve world, .003" is big enough to drive a truck through.
The other guy said his machinist was able to true it up and it works now. I have a suspicion that I could have a similar issue. Here is my theory about these husco valves. The float detent gets all crapped up by water and dirt. Then it becomes difficult to get into float. The operated forces it and the long control lever makes a lot of force on the spool. Thus bending it slightly. I suspect I could have the same issue. I just don't know how to test my theory. Also, I don't think I can buy a replacement spool. I think I'll end up replacing the valve. I just want to exhaust my options before opening my wallet
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
