L45 Accessory Power?
/ L45 Accessory Power? #1
avc8130
Platinum Member
Northern, NJ
Kubota L45
Does anyone know if the L45 has a factory aux power connector somewhere? I need to add some power for a solenoid valve. My original plan was to setup a relay off the battery, but then I thought maybe Kubota left a present for me somewhere.
ac
/ L45 Accessory Power? #2
Well - - my aux power connection comes off the fuse block. Its located just under the hood, passengers side, very near the steering wheel. The fuse block was an easy find - the aux power wire, not so much. This wire ran up under the hood and was mixed with a bundle of other wires. Persistence paid off.
Was there a fuse in the fuse box labeled "aux" or something?
Is this powered with the key on?
ac
/ L45 Accessory Power? #4
The cover of the fuse box has a diagram of all the fuses on the inside. There is one labeled Aux Power - 15A. Aux power goes on/off with the main tractor ignition key. Yes, Aux Power is on when the tractor key is turned on.
Perfect! I need to go exploring.
ac
/ L45 Accessory Power? #6
I was looking to wire up a back up light on my B3200. I notice a factory wire taped up at the back of the tractor and its a switched source. Not a real heavy gauge but runs a 30 watt work light nicely. Often the factory will have extra wiring if you did not purchase all the options.
2018 FORD TRANSIT VAN (INOPERABLE) (A60736)
2018 FORD TRANSIT...
2000 PETERBILT 379 MID-ROOF SLEEPER (A58214)
2000 PETERBILT 379...
2007 Honda Accord Sedan (A61569)
2007 Honda Accord...
2006 FRAC TANK 500BBL WHEELED (A60736)
2006 FRAC TANK...
3015 (A56857)
3015 (A56857)
2006 JLG 600S TELESCOPIC BOOM LIFT (A62129)
2006 JLG 600S...
