l4400 vs mx4700
/ l4400 vs mx4700 #21
whats this about letting a MX5100 HST idle 5 mins before killing it.when i park my tractor i let it idle while i let the loader an rear hay forks down then i kill it.
/ l4400 vs mx4700 #22
I think you guy's are blowing this turbo thing out of proportion. I've had turbo's on a lot of different diesels over the years. Having a turbo on a diesel is a positive not negative. It makes a diesel more efficient and it give a much better torque curve. Diesels aren't all about HP it's more about low end usable torque.
Worried about idling it at shut down? You only have to idle it for an extended period (5 min.) if it's been working at high load, the EGT's are high and there isn't a running at reduced load period before shut down (like driving back to the barn or garage). Under normal conditions, just let it idle for about 30 seconds to let the turbo spool down and turn the key off. It's not that big of a deal and there is a lot to be gained for the little inconvenience.
I vote for the MX5100.:thumbsup:
If you're still scared of the turbo then I vote for the MX4700...
/ l4400 vs mx4700 #23
My non-turbo'd L3940 has all the power I need, & I never have to think about a turbo: cooling it down or how expensive it's gonna be to replace it some day (hopefully later rather than sooner).
I prefer the K.I.S.S. (Keep It Simple Stup** ... I mean Sunshine) whenever possible :thumbsup:
I understand, different strokes for different folks, just giving my 2 cents.
/ l4400 vs mx4700 #24
There was an interesting thread on this a few months ago and if I remember correctly, I was on the non-turbo side. Since owning our M8540 for a few months I see concerns for longevity as a non issue for me. There is also a really old IH 1486 in our barn with a Tubo that has been very reliable over the years according to the owner.
/ l4400 vs mx4700 #25
My normal with any engine is the lst part of running the engine while parking is at near idle with no load. It might normally take up to about five minutes by the time I might be working the tractor to the time it is parked and shut off and I've not seen anything that has resulted in a failure.
/ l4400 vs mx4700 #26
I have a MX 4700 DT and it is awesome, I grade most of the time and it will pull dirt over the back of a 6' box and start off with it full from a dead stop,plenty of power!
/ l4400 vs mx4700 #27
With my MX5100HST when I get done running at or near 540 PTO RPMs I throttle down to 1000 or so and do a little clean up with the fel if I am snowplowing Then idle over to the barn and get it parked, drop the bucket and 3pt hitch, go around and wipe things down a bit and get it cleaned up, tucked it while it idles nicely then shut it down. this "wind down last 10 or 15 minutes and is time well spent. my 2c
/ l4400 vs mx4700 #28
its been my experience that turbocharged diesels get better economy than NA engines of similar power..
/ l4400 vs mx4700 #29
If I had the choice of 2 identical tractors one with a turbo and one without I would take the turbo charged engine hands down. It does fit the KISS rule.:thumbsup:
/ l4400 vs mx4700
The 5100 use quite a bit more fuel than the 4700 or the 4400. In most cases a turboed motor should be more efficient. Not the case with the 5100. I even got the dealer to admit there sum what of a fuel hog compared to the 4700.
/ l4400 vs mx4700 #31
I looked at both the MX5100 & MX4700. I went with the MX4700 for a couple of reasons. One as mentioned above I didn't like the thought of maybe having to replace a very expensive turbo charge in the future just to gain 4hp.
I don't think 4 more hp one way or the other would ever be noticed/missed.
I would like to have had the telescoping arms, but not worth the extra cost to me.
/ l4400 vs mx4700 #32
what makes you think youd have to replace the turbo anytime soon.
/ l4400 vs mx4700 #33
Having a turbo is simpler than not having a turbo? :confused2: How so?
/ l4400 vs mx4700 #34
The simplest most trouble free way to gain power and efficiency there is on a diesel. One pressure lubricated bearing. That is the sum of the moving parts. Seems very KISS to me:thumbsup:
/ l4400 vs mx4700 #35
A 40HP turbo engine is simpler than a 40HP non-turbo engine?
BTW that's one more bearing than the non-turbo engine has :thumbsup:
/ l4400 vs mx4700 #36
Hi guys...does anyone know if the L4400 HST 4 WD can lift up or down a pallet of bricks off a tray truck using a pallet forks? Can it shift timber cabins etc?
I cant get a bh92 on an MX5100 in Australia and the other bhs are too small..
/ l4400 vs mx4700 #38
id be scared to lift a pallet of bricks with l4400 even with bllast on the 3pt.id prolly step up to a 6040 to move pallets of bricks.but thats me.
/ l4400 vs mx4700 #39
can anyone explain the issue of the rollback angle is much better on the loader of the MX4700 or MX5100 than the L4400
The rollback angle is how far the bucket will tilt back and the dump angle is how far the bucket will tilt forward. The more rollback and dump the better.
The amount of rollback will be in degrees with the bottom of the bucket flat on the ground the amount it can roll back from level. For the L4400 it is about 24 degrees. For the MX loader it more.
/ l4400 vs mx4700 #40
Thanks for your opinions and explanations guys. There is so much to learn and am sure glad we have TractorByNet and all the friendly helpful guys who contribute so much experience. Its been a steep learning curve and ive just scraped the surface of all the information i need to operate which ever tractor i eventually get. I'm probably the only guy hes come across who askes so many questions...lol. Thanks again guys.
x (A68191)
x (A68191)
JOHN DEERE 5045E TRACTOR (A65057)
JOHN DEERE 5045E...
1997 HUBBLER BROS. LOGGING TRAILER (A67714)
1997 HUBBLER BROS...
2018 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2015 Jeep Cherokee 4X4 SUV. (A66738)
2015 Jeep Cherokee...
