N80
Super Member
yes you are correct 2wd would get me nowhere, fast. The M4800 is offered in 4wd, the kubota webpage makes it look like that at first glance in the photos. The 4wd M4800 is a beast compared to the L series. The 3pt is way heavier and rear axle assy. My concern if figuring out if I need that much more or if the L4400 would work just fine. What most are telling me is just get the larger unit and stop trying to figure it out.......??!!
The advice to always get a bigger tractor has no endpoint. If you can consider a 4800 then you can also consider a 6040 and if you can consider a 6040 then you can....... See what I mean? You don't really ever get to a point where you can't second guess your decision. Make a good, informed decision and don't second guess it.
I've got an L4400DT. Not in the mountains by any stretch, but still pretty hilly. I think it does very well. I also do not consider it being a geared tractor as a weakness on hills. Certainly if you try to change gears on clutch on a steep hill you run the chance of problems. But why would you need to change gears during a steep descent? Don't. Put it in the right gear and let the engine and breaks keep you in control. Heck, in 2/hi (6th gear) at idle, you will still barely crawl down as steep an incline as I'm willing to drive on. So don't worry about gear vs HST. Either one will be perfectly fine.
For me, the next step up from the L4400 would be an M5040.
