L4350 Starter/Electrical Problem
/ L4350 Starter/Electrical Problem #1
toddwulf
Cameron Park, CA.
1998 New Holland 1920
My Pop in law's L4350 was parked for 2 days and then it wouldn't start. /forums/images/graemlins/frown.gif Lights on dash were dim, sometimes bright. Starter bench tests just fine. Clutch switch seems fine. Grounded and re grounded ground wire. Not even a click out of the solenoid - Well, every once in a while. Hooked it up to my NH to jump and it seemed to work OK - Turned over but not enough juice to fire. Replaced battery - Still nuttin! /forums/images/graemlins/confused.gif Grandpa can't find his owners manual so we can't look it up. What are we missing? /forums/images/graemlins/mad.gif
/ L4350 Starter/Electrical Problem #3
Sounds like your battery was low… charge it and then…
When you first turn the key to on are you waiting for the glow plug indicator to go out before you turn the key to start? KennyV.
/ L4350 Starter/Electrical Problem #4
/ L4350 Starter/Electrical Problem #5
I have had the same problem with my 4350 for the last 2 years. I have replaced the battery, put in heavier ground wire, rewired from battery to starter and sometimes still acts like the battery is deaaaad.... I have found that by rapidly reclicking the ignition to start it will, after 5-8 x suddenly fire up as though nothing is wrong. My mechanic checked starter, solenoid, battery and resistance in wiring - nothing wrong. I hope someone can point out when this little bug lives, cause I'd like to know too!!
/ L4350 Starter/Electrical Problem #6
/ L4350 Starter/Electrical Problem #7
Have you ever tried checking or replaceing the ignition switch and checking the wire connections on the switch.The tow motors where I work will do the same thing from time to time and replaceing the switch has gotten me out of trouble a couple of times.
/ L4350 Starter/Electrical Problem #8
/ L4350 Starter/Electrical Problem #9
There is a fusible link that plugs in near the starter - a heavy red wire loops out and back into a white plug. They get corroded and then don't conduct enough power at normal voltage to run the solenoid and/or starter. Try unplugging and re-plugging it. Or try jumping it with another wire. I keep a spare new one hanging on a peg. As always, prompt cheerful refund if info is bogus. Take care, Dick B
/ L4350 Starter/Electrical Problem #10
Hmmm, Another 4350 owner with the same symptoms. This has happened before, but re grounding the ground wire seemed to clear it up. We haven't waited for the glow plug light to go off and will try that. For the key swx, we did hear some electrical noise from under the dash, pulled it and everything appeared normal - Perhaps a R&R is in order but maybe I'll look at hotwiring first to see if removing the swx solves problem. We did check the heavy guage looped wire - It's not fused (atleast I didn't think it was) and I did pull apart, inspect and re connect - I'll have to do that again as well. For the wiring, we get the same voltage reading from the new battery posts or from the positive term on the starter, so it's not that wire anyway. Perhaps changing the ground cable as well. I hate electrical problems - They are not easy buggers to track down. Keep the advise coming - We'll get this figured out. /forums/images/graemlins/tongue.gif
OK Folks - An Update. We are suspecting the key switch and possibly or (perhaps only) it is the relay between the key switch and the starter. The relay is suspect as when we apply power from ignition lead on key swx to starter lead on key swx, the realy buzzes/vibrates. The key swx is suspect becuase it's in the chain - With key on, no dash lights. Key to start produces nothing although voltage drops on both positive leads when keyed to start. Also, key swx off lead indicates voltage even when key is off. Neither me nor pop in law are good electrical engineers so even we suspect our suspects! Any thoughts? /forums/images/graemlins/confused.gif
/ L4350 Starter/Electrical Problem #15
I looked in my manual (L4400) and there was no electrical diagram.There is a fuse chart and on mine #3 fuse which is a 10 amp is panel lights,#5-5amp is key stop,#7-5amp is for the starter relay,and#8 which shows to be three big fuses beside the battery,I assume protects intire elect. system.If none of these are blown you might try turning the key on and wiggleing the wires at fuse block and any other connections and watch for lights to come on.This would tell you if it is a connection problem.If nothing happens I would suspect the key switch.Maybe some of this info. will help.GOOD LUCK!!!!!
/ L4350 Starter/Electrical Problem #16
2006 John Deere 6420 (A64126)
2006 John Deere...
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
John Deere Pallet Forks (A66285)
John Deere Pallet...
