L4330 not cranking
   / L4330 not cranking #11
Tilt the seat all the way forward. This is the position for PTO operation without sitting in the seat ie, irrigation pump.
Other than that you need a 12v test light and a helper,, then begin at the starter and work your way back,, B/W wire on starter to start relay to 30A fuse to key switch.
Other Idea's try and use jumper cables and jump start it with + lead connected right at starter.
If nothing else jump the starter momentarily and see if it hits.
Check your battery to frame ground at the frame..
Or get someone near you to help,, Likely something simple just finding it can be difficult.
Good luck.
Got cranked. Problem was the extra wire. It was the wire that goes to the solenoid. The male end was broken so smoothly at the plastic that it was unnoticeable. The tit was still in the plug.
Now to figure out how to fix it. To crank I made a wire to plug back in the extra wire and had someone touch the brass edge that was on the starter.
   / L4330 not cranking #13
Excellent glad you found it,,, Sorry to complicate things,, extra wire was the clue I missed it. Thats a good tractor I have one myself. fix it, enjoy it, be safe.
   / L4330 not cranking #15
Kuboman said to check all safety switches. Where are they?
I am having exact same problem. Please post if you find out whats going on!
Tractor used to start when not in seat as long as its not in gear and in neutral. So I ruled out seat switch.
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
Electric Scissor Lift (A50322)
Electric Scissor...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
