L4310..buy?
   / L4310..buy? #1
zenmek
Kentucky (in the bluegrass!)
Kioti LK3054, IH cub cadet 782, Grasshopper 721D2
I need a favor from the Kubota forum! I have a buddy looking to buy a L4310 or L4610 with a FEL and hydrostat transmission, are there any good/bad/otherwise comments that I can forward to him? I would greatly appreciate it!
   / L4310..buy? #2
I have an L4310HST w/FEL. No problems. A pleasure to use.
   / L4310..buy? #4
I just bought an L4310HST, Ag tires, FEL and 72" rotary cutter. I only have 10 hours on it so far but it is doing everything I want it to do. The HST came in handy when I was mowing over a small narrow stream. I could just back up over the stream, pull forward and over, back up etc., to mow both sides. I also looked at the 4610 but my dealer made me a much better deal on the 4310, said I would not even notice the horsepower difference. I got the package for $21,300 delivered.
Larry
   / L4310..buy? #6
I have a 1999 L4310 4WD HST with ~325 hours. No real problems that I did not cause myself. If money is not a big concern, and he is thinking of getting a 4:1 bucket some day, the extra lift of the L4610 will come in handy. A empty 4:1 bucket can weigh over 400lbs verses the standard bucket at ~200lbs. The L4610 also has a heavier front axle. Otherwise I would go with the L4310. Horsepower has never been a problem. If he is buying new, I recomend he spend a little more and get radial tires up front for better traction. He will probably never wear out a set of tires if he only uses the machine for occasional work.
   / L4310..buy? #7
zenmek
I am very pleased with my L4610. Make sure he gets the tires loaded/w3tcompact/icons/wink.gif.
regards
Mutt
   / L4310..buy? #8
I have owned my L4310 cab for a little over 2 years and 300 hours and it been a great tractor. But the parts are very expensive. Right after my two year warranty expire so did the tachometer at about $500 and the air conditioner compressor at $750 to $950 for the part alone depending on the dealer.
John
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
