L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #11
I've seen this set up on many of the GL 40 HST series tractors. When I service them I simply remove the hose with out removing the guard. It will drain like that. On the HST units you'll need to remove the drain plug on the bottom of each rear Axel housing as well to get it all drained off.
Incidentally my Kabota 2011 5740 has the same set up as yours but my 2008 4240 had a different set up for the third function valve without that hose in the bottom. Both are oem 3rd valve set ups. image.jpegThe 4240 is a very nice machine. :thumbsup:
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #12
Paul, my brother is going to do a 400 service on our 5740 this winter, are the drains on the bottom of the axles mentioned in the manual?
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #13
I wouldn't accept that. I have a mid PTO so that cover is replaced by the mid PTO shaft. I don't have a 3rd function valve but I do have a return line for the front snow blower. It goes into the case on the side. I think you can see the plug in the upper right corner of 4shorts picture. Hanging down like that just looks like an accident waiting to happen. While the fitting may be protected that hose could get caught on a branch. Between the mess it would make and the possibility of having to repair it in the field would suck.
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #14
Yes sir. There is one on each side of the rear axel.
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #15
No drain plug. you remove the hose at the pipe. Have you ever studied the mess of hoses hanging on the new 60 series. What was Kubota thinking?
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #16
I haven't looked at the 60 series. I have seen the fuel tank and didn't like the location. I've broken more than one fitting on my backhoe because a hose got caught on something, once a log buried in the dirt, breaking the weak link. I now have a set of easy outs to remove the fitting if it breaks off at the threads. That's my backhoe, something big and lumbering that really doesn't go into the woods. I guess if your tasks are plowing a field then it wouldn't matter but for me on a tractor I want it to be as bullet proof as possible.
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #17
Woods work is tough for on equipment. I've torn off steel lines on a Cat D-9 in the woods. Took windows out because of trees. If I were using the tractor in the woods I'd put a full skid plate under it and a cage over it. I was horrified looking at a 6060 last year with hoses outside the FEL and hoses hanging under the rear wheels. I get emails from their owners asking if something can be done about it. Nothing worst than having to repair that sort of thing on site.
Incidentally my Kabota 2011 5740 has the same set up as yours but my 2008 4240 had a different set up for the third function valve without that hose in the bottom. Both are oem 3rd valve set ups. View attachment 448737The 4240 is a very nice machine. :thumbsup:
It's nice to know you've seen this before, that helps.
Thanks for your reply, I've admired your work on your tractor for some time.
It didn't end up being as bad as I thought. Below is a picture of the trajectory of the fluid as it started draining when I removed the hose. The fluid from the axle drains actually came out a little more horizontal, I think because the drain hole and plug are smaller.
One thing that was a *big* help was the Home Depot 20 gallon Concrete Mixing Tub that I bought:
Plasgad Black Large Concrete Mixing Tub-887102C - The Home Depot
It was suggested in an older post on Tractorbynet, it's large enough that it can be oriented to be under all three drains at the same time and at $13 the price was right. I used two small pans with one under each filter as well and I didn't have any spills. I'll use a pitcher to get the used hydraulic fluid from the tub into the jugs the new fluid came in to get it to the recycle place.
Thanks for the replies to my post, this forum is great.
Fluid trajectory:
Tub:
   / L4240 w/LA854 and Third function valve: question on draining Hydraulic Fluid #20
Is 4th plug a recessed hex? Size?
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
5TH WHEEL HITCH (A57192)
5TH WHEEL HITCH...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52707)
2019 CATERPILLAR...
