4shorts
Elite Member
I've seen this set up on many of the GL 40 HST series tractors. When I service them I simply remove the hose with out removing the guard. It will drain like that. On the HST units you'll need to remove the drain plug on the bottom of each rear Axel housing as well to get it all drained off.
Incidentally my Kabota 2011 5740 has the same set up as yours but my 2008 4240 had a different set up for the third function valve without that hose in the bottom. Both are oem 3rd valve set ups.
The 4240 is a very nice machine. :thumbsup:
