L4200 fan belt replacement.
/ L4200 fan belt replacement. #1
Luath
Canada
Kubota L4200
Hi Guys,
Could somebody point me in the direction of a step by step guide to replace the fan belt? I've no prior knowledge of the procedure.
Thanks,
Luath.
/ L4200 fan belt replacement. #2
The tension adjustment is the starting point...
Loosen the bolts that hold the alternator, then swing the alt in toward the engine, remove the belt from around the fan while fishing it out from inside the fan shroud, reverse the procedure to reinstall new belt.
BTW, if you actually Remove the alternator and then place the Shortest belt possible on the pulleys and then (With a little difficulty) remount the alternator... You will gain a little better access to the Oil fill port, located beneath the alternator... that is not really necessary but it is a little handier for my annual engine oil changes ... L4200 is A Great tractor, I love mine. KennyV
/ L4200 fan belt replacement. #3
The Best (though takes a little finessing to install) is the Gates 9420 same as Gates 13A1065... It is available at O'Rileys auto parts and a lot of others... KennyV
/ L4200 fan belt replacement. #4
This is a couple pictures of the belt on My L4200.... KennyV
/ L4200 fan belt replacement. #5
I recently had to replace my air conditioning belt(three hours later) I removed the muffler and was done in minutes.A little PB Blaster on the bolts and they came right out.This was on a L4240 Kubota.
/ L4200 fan belt replacement. #8
My MX5100 belt must have stretched, or just wore out. Over the last 5 years I've incrementally adjusted the tension with the alternator and now it's all the way out. I haven't put much tension on it, just adjusted to spec. Next is replacement I suppose.
/ L4200 fan belt replacement. #11
Hello Jay... Love my A/C, but also would Love to have Your Backhoe. KennyV
Come about February, I'd trade that backhoe for your cab in a heartbeat :)
F'n deep snow, eh?
Thanks guys.
One or two folks have told me that the older Kubota is actually a good beginners tractor. Less electrical systems etc.
Luath.
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY  CAB (A59905)
2018 FREIGHTLINER...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
SWICT 60" SKID STEER BUCKET (A60430)
SWICT 60" SKID...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2019 Ford F-150 Pickup Truck (A59230)
2019 Ford F-150...
PALLET OF (5) INDOOR CABINETS (A60432)
PALLET OF (5)...
